White Ink Solution – GCC StellarJET 183UV
White Solution
A Versatile Feature of the GCC StellarJET 183UV
GCC, a global forefront equipment-manufacturing provider in the visual-tech industry, proudly introduces White Solution — a truly versatile and unique feature of the GCC StellarJET 183UV curable inkjet printer.
GCC’s Research & Development team has successfully developed the White Solution for the GCC StellarJET 183 UV inkjet printer. “More and more companies provide white ink options on their grand format UV-curable inkjet printers, but to large format UV-curable inkjet printers with white ink option are not so common in the marketplace at present. Therefore, the White Solution is a great advantage for us to differentiate our GCC StellarJET 183UV from others.” stated Sophie Chang, product marketing manager of GCC.
The White Solution can be applied in the following three primary applications: base, overcoat and spot colour. White Solution as a base is widely used in coloured (non-white) or transparent substrates; moreover, applying the White Solution as an overcoat allows users to design a two-sided image, viewable through transparent media. Also, users can apply White Solution as a spot colour to highlight and present the most vibrant graphics. With White Solution, GCC StellarJET 183UV users can easily print a wide range of vivid and rich digital outputs on any transparent and/or coloured (non-white) media, offering possibilities to create an extensive range of applications.
Responses
