ORALITE® 5090 Film Sets Industry Standard for Dew-Resistant Road Signs
ORALITE® 5090 Anti-Dew Film: Advanced Protection for Reflective Road Signs
ORAFOL has expanded its ORALITE® range with the introduction of ORALITE® 5090 Anti-Dew Film, a high-performance transparent PMMA overlay engineered to maintain retroreflective performance in dew-heavy and humid environments. Specifically designed to combat visibility issues caused by moisture accumulation, the 5090 Anti-Dew Film ensures reliable legibility of traffic signs even under challenging atmospheric conditions.
Reliable Anti-Dew Performance for Long-Term Road Sign Clarity
Functioning as a self-adhesive protective overlay, ORALITE® 5090 prevents dew droplets from forming directly on the surface of reflective signage. This ensures consistent optical clarity, enhancing road safety by maintaining the integrity of reflectivity during early mornings, fog, or sudden humidity shifts.
Tested under Central European conditions, the film delivers up to 10 years of functional anti-dew performance, matching the durability of the reflective sheeting it’s designed to protect.
Technical Specifications
- Material: Transparent PMMA (acrylic)
- Thickness: Approximately 0.12 mm (75 µm)
- Adhesive: Solvent-based permanent polyacrylate with PET release liner (one side coated)
- Outdoor Durability: Up to 10 years (vertical exposure, standard European climates)
- Shelf Life: 2 years (original packaging, 20 °C, 50% RH)
- Temperature Resistance: –56 °C to +90 °C
- Chemical Resistance: Compatible with cleaning agents and seawater
Standards Compliance and Reflective Sheeting Compatibility
ORALITE® 5090 Anti-Dew Film is compatible with a range of ORALITE® reflective films, including:
- 6910 Brilliant Grade
- 5910 High Intensity Prismatic Grade
- 5810 High Intensity Grade
When correctly applied, it preserves compliance with global retroreflectivity standards, including:
- EN 12899-1
- DIN 67520
- ASTM D 4956
- JIS Z 9117
In addition, its crystal-clear transparency maintains the visibility and vibrancy of underlying graphics, including ORALITE® 5019i UV digital prints, without compromising reflectivity or colour accuracy.
Application Guidelines
For best performance:
- Apply only to clean, dry surfaces.
- Remove the water-soluble protective coating prior to exposure to sunlight or long-term storage.
- Observe proper environmental controls during application and curing.
- Avoid damp environments and maintain vertical orientation during lamination and storage.
Responses
