Home Forums Sign Making Discussions Vehicle Wrapping Wrap film adhesion fail, advice on problem please?
  • Wrap film adhesion fail, advice on problem please?
    Posted by Richard Urquhart on 3 August 2018 at 15:37
    Hi guys we have wrapped many vehicles and would like to know if your having any issues with the heat and humidity, we had a job fail with easy curves and when I was Fitting noticed the initial tac was poor, using hx20000
    I know it’s hot but could the weather cause adhesion problems and pulling out of very simple curves all post heated etc etc
    Richard Urquhart replied 7 years, 3 months ago 5 Members · 9 Replies
  • 9 Replies
    3 August 2018 at 15:54
    Was it printed?
    if so, type of machine etc?
  • Richard Urquhart
    3 August 2018 at 16:09
    HX2000 skintac normal wrap film unprinted used loads before not had this problem
    3 August 2018 at 18:23
    by any chance do you have a picture Rich?
    "Humidity"
    The only downside of humidity that i have experienced is that the initial tack of the vinyl can increase.
    By that i mean it sticks on contact and needs a bit of a sharp snap back to lift it. This was some years back and was a regular adhesive on the vinyl, no air channel or levitating adhesive system.
    Could it be possible there is a wax/polish on the vehicle?
  • Jamie Palmer
    3 August 2018 at 19:02
    Had a similar issue last summer, but put it down to residual polish, since then always use the 3 step cleaner they sell. Tech spec on film leans towards install temp of 20 – 25 degrees and if you have post heated I usually go to 95. We deal with Marcus there and in the past he has attended when I have had concerns might be worth talking to him. Good luck
  • Richard Urquhart
    3 August 2018 at 19:14
    Thanks guys I don’t have an photos as I peeled it off, it failed in a couple of places and that we’re not under any real stress, I’ve ordered another roll of material and also their final cleaner(I used Avery surface cleaner) so it was cleaned well before hand. Strange one will re wrap on Monday and update
    6 August 2018 at 08:34
    Can’t say I’ve had vinyl fail, other than one attempt to apply some lettering to a matt black wrapped that turned out to be almost 60°C – even after 10mins out of the sun!!
    I have really struggled with the last batch of oracal application tape though, just won’t stick to anything, bought a cheaper spandex alternative which I have to say has not missed a beat.
  • Richard Urquhart
    11 August 2018 at 16:59
    Just a quick update guys, the job was a repaired vehicle and where the new paint was blended to the old (ie not the complete panel painted) was where the wrap failed, we asked for the paint to be redone and we left it for sometime before we rewrapped, the outcome was perfect and we can only put it down to where the repair was done, thanks Rich
  • Martin Cole
    14 August 2018 at 10:22
    Glad you got it resolved Rich,
    out interest who’s footing the bill for the wasted material, time and effort?
  • Richard Urquhart
    14 August 2018 at 10:41
    me mate, very good customer and just put it down to experience lol,
