Activity Feed › Forums › Sign Making Discussions › File Swapping › Woodworking plane image match required
Posted by John Harding on January 7, 2011 at 6:02 pmHi all this is my clients image drawn by his father apparently – does anyone know if there is there a close vector or decent printatble image that closely replicates this to save me a detailed redraw
Thanks for looking 😀
john
John Harding replied 13 years, 4 months ago 6 Members · 11 Replies -
John I think re sized in signlab you could get a good print from that mate !
ok rich will get you 2 try and resize it for me m8 i will send you file over asap ta
yes do that mate and I will run it through super size image, let me know final size Rich
see if this helps will need tidying -
quote Dave Rowland:u need to sort the levels out as well
is that the spirit level Dave?
Thanks all – kevin nice scan will tidy if I cant print successfully thanks m8 😉
Earth to Dave – come in dave 😀
that looks good John, but it doesn’t look like its a cutable vector, with so much fine detail, would it not have been better just to scan and print the original?
peter in a way yes but also I want the option of scaling it up for the panel of a sprinter so only a couple of feet square as a background image – so at least as a vector i can readily change the size and print (no need for it to be cutable) just want to avoid pixellation – hence richs solution would work also but I dont have signlab.
