Home Forums Sign Making Discussions General Sign Topics Window Graphics
  • Window Graphics
    Posted by Chris Hooper on 2 July 2005 at 12:27
    A bit of advice please – we are working with a design agency who printed window graphics – about 6 sq metres – to window film using pigment/dye inks. We installed as requested to 2nd surface. Installation OK but the whole thing lacks “pop and vibrancy of colour” – End user is high street photo processor. We expressed reservations on this method – however at the end of day you follow your instruction.
    The brief is now – to reprint – customer hesitant about applying solvent print to first surface equally wants the same look to be seen from inside.
    I am thinking solvent print – outside digital print finish with laminate, mirror image and apply same inside. Although lining up may be a problem.
    Am I on the right track here or am I missing the point and we could do this easier.
    Thanks in anticipation of your advice
    Chris
    Chris Wool replied 20 years, 6 months ago 2 Members · 3 Replies
    2 July 2005 at 13:27
    come across this before but how can you have the same look inside cos its reversed from the outside ? or have i hissed the point
    i am playing with a printable one way vision mesh at present looking good
  • Chris Hooper
    2 July 2005 at 14:17
    Chris
    No you are on track with that – no problems with the images they can be reversed – text however is a problem. One way vision stuff is a possibility but I am concerned we loose the colour on this.
    Thanks tho
    2 July 2005 at 14:49
    as long as its all contained with in a symmetrical shape i have done this before to the inside of a window .
    print on to clear reversed
    fitt white backing
    fitt black backing as block out
    fitt inside print (on white) over the black
    with out the black at night with the shop lights on the image will be messy from the out side
