Home Forums Sign Making Discussions Vinyl will i get a reaction from the vinyls im using?
  • will i get a reaction from the vinyls im using?
    Posted by Peter Coogan on 14 March 2006 at 08:30
    I have to apply Chevrons to a Transit van I am thinking of putting a strip of 5year vinyl along the bottom & applying the reflective on top of that will I get a reaction from the Vinyls I am using
    Justin Kirby replied 19 years, 8 months ago 4 Members · 4 Replies
    14 March 2006 at 08:50
    You wont have a problem, and it will make the reflective much easier to remove, If you explain this to your customer they will usually be happy to pay the few quid extra.
  • Peter Coogan
    14 March 2006 at 10:42
    Thanks Peter for your prompt advice
    Peter Coogan
  • John Harding
    14 March 2006 at 20:50
    ive done this the other way round. block of reflective with standard vinyl over because its easier to cut and weed standard vinyl, some reflectives are easier to remove than others but be wary of this aspect as peter has pointed out!
  • Justin Kirby
    20 March 2006 at 03:45
    It might be a little late but Avery Nv 1300 series reflective vinyl is removable.
    I have applied it and removed it off several courier vans for a client. It cuts and weeds quite well. When it is time to remove it, it separates from the adhesive so there is a lot of adhesive to clean off but does not break up into little pieces like the old reflectives used to.
