Home › Forums › Software Discussions › Corel Software › why is the weld option not visible please?
Posted by Jo-Ann on 29 May 2008 at 21:04Hello, me again
I was just wondering, I am playing around trying to get together with corel. I have some words that i am trying to cut in a fancy font.
When it cuts the tails of the letters bleed into the next letter.
I can’t remember what I was told about how to get rid of this??
I really hope you don’t mind helping out such a simpleton.. But we all have to start somewhere..Thanks again guys, you don’t know how much of a life line you are.
Jo-Ann
Graeme Harrold replied 17 years, 7 months ago 7 Members · 22 Replies -
You should be able to select all and then weld…….without converting to curves. What version are you using?
Select all the letters, go to Arrange and and then Shaping and select ‘weld’
Ok,
I am not as bad as i thought i was!!, I have done that but the weld option is not highlighted, It won’t let me do it?
Is it highlighted when you try something else? Try two outlined boxes, select all and weld. Not sure what is wrong. Post a pic of what you are trying t weld maybe?
Maybe you have more than one layer?
In Corel 9, I always had to weld before combining.
Otherwise it would be choppy with holes where it should have welded.
But it converts to curves as it welds.
Can’t remember what I do in Corel 12.
Now I’ve confused myself!I think I’ll have another beer.
Bud Light Lime.
Much nicer than Miller Chill.
Love….Jill -
Ive just tried it in V12 with some text in an overlapping font (only see it when you remove the text fill). The weld option is not highlighted, however in V12 (might be the same in X3) look in the "Window" menu option, select "Dockers" and then open "Shaping" which is basically the weld tools.
bingo.. Now it wont cut but i think i’ll tackle that tomorrow.
Rome wasn’t built in a day and neither will my new business…. 😀
Thanks again guysBye for now!!
Jo
Xx -
What machine do you have, and are you cutting direct from Corel?? Might need to change your line colour or thickness based on your machine prefs………
Well i have got a graphtec ce5000-60 with coreldraw.
To explain why i am such a spanner – I got the cutter last year with Coreldraw, i have always used computers easily and thought that it would be "Easy" to teach myself, I have finally got around to using it hense the reason for the initial glitches and very simple" questions.
You never know until you try things – And boy am i lucky that I found you guys or all hope would have gone out the window.
Excuse me if i don’t understand technical terms, it’s just that this is all new.
Thanks againJo
just tried it in V12 and as Harry said no need to convert to curves. I typed the text selected all with no fill and changed the outline (f12) to 0.001mm then welded all worked fine.
quote David Evans 1210:just tried it in V12 and as Harry said no need to convert to curves. I typed the text selected all with no fill and changed the outline (f12) to 0.001mm then welded all worked fine.
F12 Love the shortcut….thanks.
Ive now got into the habit of setting the default line width before I start doing anything. Blank canvas, select the line thickness with nothing selected and it brings up an "apply to" dialog box and I tick it all and then set the line to .001 and off I go…………
Good idea, still now i send a job to print and nothing happens, after several attempts i realise that the outline is not 0.001 change that and oh what a surprise it cuts!!
i dont know where this .001 mm line comes from it should be a hairline which is the first line selection of the pen nib bar.
somebody is going to tell me that a hairline is .001mm if i put in .001 mm in my v10 is says none.it can be any outline that is less than .01 mm but the first option is the preferred one due to its ease of application.
if you make multiple sizes of the same object please ensure that the scale with object line thickness is off.
Not sure what cutter you use Chris but in v12 if i select hairline nothing, if i use .001 it fires up (just what grafityp told me). I use a GCC Signpal.
sorry if bum info
i have used direct from corel summa roland and graphtecs these all work the same.still cant set my v10 to .001mm
Must be V12 as its the same for my pc60 aswell, maybe hairline is .001 in v10 but not in v12, Just a thought
Ive got a GCC JaguarIII and it will not cut hairline, instructions form Grafityp was to use .001mm and I have to set it each time…minor pain in the butt!!!!! however Corel is the program Ive been using since V4!
If you attempt to change the line thickness without anything selected it will ask if you want to do this from now on for graphics text etc. change line thickness to 0.001mm and apply and voila. Now all new objects will have that thickness instead of hairline (which works for my Summa through winplot and Mistral/Posterprint).
Save your workspace options prior to closing and this should stay the same each time you fire up CorelDraw.
quote Colin@BECC:If you attempt to change the line thickness without anything selected it will ask if you want to do this from now on for graphics text etc. change line thickness to 0.001mm and apply and voila. Now all new objects will have that thickness instead of hairline (which works for my Summa through winplot and Mistral/Posterprint).
Thats what I have done with Corel X3 and my Graphtec, works a treat.
Will have to give saving the workspace a go as I was not aware that the .001mm setting would be retained as its not one of the default thicknesses…………many thanks for the tip
