Home › Forums › Vinyl Cutter Discussions › PCUT Vinyl Cutters › why is my P630 plotter not cutting correctly?
Posted by bertsgraphics on 4 July 2007 at 18:33Hi All my name is Charlie and I Run Berts Graphics.
We have a problem of that when we send a job to the cutter of a large size, or batch cut, a shot while into the job the blade goes down and then returns to point of origin with the blade down so it cuts, wasting material.
Any idea what it could be? happens n every program even pltdraw.
im using P630 USB, new acer laptop. on a 10m extension USB Cable.
Any ideas anyone? driving me crazy and costing me money.
any help is much appreciated.Initial_G replied 18 years ago 8 Members · 22 Replies -
Not sure here mate, But you said you are using a 10m usb cable. I’ve always been told to use a shorter one as the info starts to get scrambled.
I’ve never used a cable that long so have no experience of the problem. (?) -
thanks Karl i will try using without cable… is there any way of getting the cutter not to advance to where it started from on the job?
anyone elce got any more ideas??
ok, now it just pauses when it gets to the same point and displays "waiting" on the cutter???
Er? 😮 Try using without cable? I said shorter mate, not no cable.
I don’t know your software, but you should be able to control the start and end points from your software. You did say you are using a new laptop. Maybe it’s set up wrong. -
Hi Karl , just took the ext cable away and using USB lead that came with the cutter.
Iv set up the cutter using the set up guide in this forum
im using flexiSIGN -
In flexi there will be an icon that looks like a Plotter in the cut menu. click this and it should read your media width. Not clicking this will cause problems.
thanks for the fast replys karl, iv set my media. but still have problem 🙁
any more ideas oracle??? please! -
don’t know this cutter but do you need to clear the memory, so it holds no reference to previous jobs 🙄 just a thought
manual! u got to be kidding its a p cut hehe.
it seems turning the flow control OFF cured the problem. so its not set to hardware!..
thanks for the help tho 🙂
dont really use it, i mostly use pltdraw just wanted to diag the problem
When you say it pauses, how long have you left it? Mine when cutting a big job with lots of cuts to be done also pauses but after a while when it catches up then it restarts, sometime it can be as long as 5 mins.
Also check the baud rate, if not do as Lynn says and clear prefrences. -
quote Brian Hays – Impact:Another P-Cut Flexi combo eh? 😮
… :lol1: :lol1:
Is that supposed to be a dig at me David? 🙁
Who gives a toss what cutter i’m using. It works for me, and i did’nt say that i used Flexi, i actually use Signgo and Artcut.
I used to work for a firm that used Flexi, thats all i worked on. When i set up on my own i bought the cheapest set-up and it’s worked for me ever since. 🙁 🙁 🙁 -
quote Glen Mathers:Is that supposed to be a dig at me David? 🙁
I used to work for a firm that used Flexi, thats all i worked on. When i set up on my own i bought the cheapest set-up and it’s worked for me ever since. 🙁 🙁 🙁Jeese! Touchy!
It was actually a reference, almost an inside joke, to the PAST saga of £3000 software for £300 plotters. NOT directed at YOU or the original poster Charlie…just an of-the-cuff nod / smile to Brian’s comment.
I KNOW there is nothing wrong with Creation P-Cuts once you get them configured (what most posts concerning them are about) and the like and if I wanted a cheap machine for lighter use it’d certainly be one to consider. Also, if that’s all somebody’s budget stretched to – fine.
Now I’m NOT saying that the Flexi that’s being used is anything but 100% legitimate – as I don’t know and have no way of knowing. So NOTHING is being inferred by ME in ANY way.
quote Glen Mathers:Point taken, sorry to be a bit blunt Dave 😀
No worries mate!! It’s hard to get ‘inflections’ in just type eh!…or a smirk 😉
Not sure you sorted it out yet but this sounds to me like you have setup the wrong p-cut in flexi.
I know this will sound crazy but you need to select creation-HK then CT-635
I had this problem after my comp crashed and I had to reinstall everything.
I had the same problem on my Pcut 630.
I got rid of the prob by getting rid of the USB cable and using the RS232 one.G
