Home Forums Printing Discussions General Printing Topics why is my laminator not powering up
  • why is my laminator not powering up
    Posted by Karl Williams on 20 July 2009 at 11:54
    Can anyone throw any suggestions my way. I have an Artic Titan Laminator (Cold). The other day I was flood coating some boards when the thing just packed up part way through a job. Now It won’t boot up. I’ve checked the fuses…..all the connections inside on the switch……had the fuses and the switch tested. All the connections on the main board are secure. I’ve also tried 2 different power leads but still no results.
    Just hoping there is a nice person reading this who can help!! 🙁
    Karl Williams replied 16 years, 5 months ago 7 Members · 12 Replies
  • 12 Replies
    20 July 2009 at 11:55
    Have you paid your electricity bill recently 😕
  • Karl Williams
    20 July 2009 at 11:56
    quote Phill:
    Smart @rse!
    20 July 2009 at 11:57
    could it be a duff PowerPoint karl?
    i had this only last week… did everything and it ended up the socket i was plugging into that was at fault. 😕
  • Karl Williams
    20 July 2009 at 11:59
    I’ve got 2 small light boxes near the Power point mate so tried these in the socket. These both power up so I’ve ruled that out.
  • Karl Williams
    20 July 2009 at 12:15
    Bumping the thread up!!!!
  • Tim Painter
    20 July 2009 at 12:29
    So Karl you have mains to the switch and out from the switch?
    Does this then go to a power supply that converts the AC to DC?
    Which goes to the main board or is the power supply incorporated in the main board?
    Tim.
  • Ian Muir
    20 July 2009 at 12:46
    If only a cold lam then would think there’s no dastardly electronics … so, as said could be power supply if it has one i.e. motor is not 240ac.
    Then to the motor
    Does it had an illuminated panel, does this light
    Only other thing which is decidedly possible is safety switch/es connections or switches themselves.
    Ian :lol1:
  • Karl Williams
    20 July 2009 at 13:05
    All sorted thanks guys. I checked the fuse next to the switch and they were ok. But I didn’t realise there was another fuse next to the main board. This one had blown. New fuse and hey presto we’re back in business!
    Thanks for the replies.
    Karl.
  • Karl Williams
    20 July 2009 at 18:36
    I think I spoke to soon! 👿 Fitted everything back together….booted up again and bang, the fuse went again.
    20 July 2009 at 20:37
    does it go ‘bang’ when u ‘activate’ the rollers or when it is ‘idle’?
  • Graeme Harrold
    20 July 2009 at 21:22
    Karl,
    Check your rollers, if there is excess resistance, your motor will draw extra current and blow the fuse, could be time for a clean and lube 😮
    Ive heard you like to grease your shaft :lol1: :lol1:
  • Karl Williams
    21 July 2009 at 08:19
    Dave, the first time I booted it up the casing and back was off. The power light came on no problem. When I put everything back together and went for the second boot up it went as soon as I turned it on.
    Graeme………As for greasing my shaft……….you been spying on me again?? 😀 😀
    Thanks guys.
