Home Forums Printing Discussions Mimaki Printers why does the rockhopper stop halfway through prints?
  • why does the rockhopper stop halfway through prints?
    Posted by Mathew Gibson on 3 March 2008 at 12:19
    Does anyone use this machine and had problems with the machine stopping halfway through prints. Had engineers out they keep fobbing me off saying its my pc tried 2 different pcs still happens? Any Ideas
    David Rowland replied 17 years, 10 months ago 5 Members · 17 Replies
  • 17 Replies
  • Karl Williams
    3 March 2008 at 12:29
    What Rocky is it?
  • Mathew Gibson
    3 March 2008 at 12:59
    rockhopper 46" mate
  • R Ferguson
    3 March 2008 at 13:05
    Hello,
    I dont know if this wold help. but on my valuejet I had the same problem.
    To fix the problem I had to add a Window’s printer with the same ip address as my printer. I was told this by spandex.
  • Karl Williams
    3 March 2008 at 13:30
    Right then. The Rocky 46 as far as I’m aware is only a larger version of the Rocky 38. You’ll probably find the main board voltage is set wrong as it was on the 38. What happens is the job being sent to the buffer gets confused as the timing is out due to the voltage being incorrect. An electrician would be able to sort this for you. The correct setting is 4.2.
    I wouldn’t say there’s anything wrong with your computer. They said the same to me and the computer/s were fine.
  • Mathew Gibson
    3 March 2008 at 13:44
    Ive tried the windows printer but it still does it! was yours stopping half way through prints aswell karl did doing this sort yours???
  • Karl Williams
    3 March 2008 at 13:50
    Yes and Yes. Mutoh, according to Artsystems sent a batch out with the voltage set wrong. As soon as this was set correctly there were no more issues with this particular problem.
  • Mathew Gibson
    3 March 2008 at 14:05
    i think i best pay you instead of the monkeys that have been charging me to TRY and solve the problem!!! How exactly do you fix it?
  • Karl Williams
    3 March 2008 at 14:11
    Artsystems fixed it mate. I’m only round the corner from them so the guy stopped off on his way home. The board is in the big black box under the printer.
  • Mathew Gibson
    3 March 2008 at 14:35
    did you get your rockhopper from them?
  • Karl Williams
    3 March 2008 at 14:37
    No mate you can’t buy from Artsystems only from a reseller. Art take care of the warranties.
  • Mathew Gibson
    3 March 2008 at 14:43
    have you got a number for them?
  • Mathew Gibson
    did you buy from spandex by any chance
  • Karl Williams
    3 March 2008 at 14:45
    Check your pm’s mate
  • Mathew Gibson
    3 March 2008 at 14:50
    cheers karl youve been a great help
  • Karl Williams
    3 March 2008 at 14:51
    Anytime mate. 😉
  • Gian Gavino
    3 March 2008 at 15:59
    hi
    Perhaps the problem is the same.
    My left of the white lines.
    I solved by connecting the PC to direct plotter, without hub.
    Now works fine. Maybe it faster.
    I bought in Italy by spandex,
    They are very good and available.
    Gavino
    3 March 2008 at 20:29
    to be honest i have seen a network hub for donkeys years.. if it is a network ‘switch’, these handle data correctly.
