Home Forums Software Discussions Signlab Software why does the grid on screen keep disappearing?
  • why does the grid on screen keep disappearing?
    Posted by j.j. on 14 November 2005 at 23:15
    Hi every/anyone, just found this board & it looks to be a great idea to me.
    My question is-does anyone use the Signlab software? if so, here’s my problem-I seem to keep losing my grid for no reason, one day it’s there, next it’s gone. The only thing I’ve discovered so far is that it seems to appear/disappear with the changing of the sign blank size, haven’t found a pattern to it but it will show on some & not others.
    Anyone had this error & found the answer to it?
    JJ.
    j.j. replied 20 years, 1 month ago 4 Members · 5 Replies
    14 November 2005 at 23:18
    the grid maybe set to say 1 inch by 1 inch squares. so if you have small sign blank you see it coz your up close. but if the sign blank is huge, the grid disappears.
    14 November 2005 at 23:21
    Hi JJ
    welcome aboard.
    signlab is quite a popular prog and used by quite a lot on here.
    Does the grid actually disappear, or if you zoom in can you see it?
    The grid will not show if set at a small size and the blank is large, if you see what I mean?
    welcome jj 😀
    was going to say the same, but someone beat me to it 😀
  • j.j.
    14 November 2005 at 23:36
    Hi again all
    Thanks for the replies, I’m away for a mo to check out a ‘zoom in’ ‘cos I have not tried that yet-I’ll keep ya’s posted & thanks for the welcome.
    JJ.
  • j.j.
    14 November 2005 at 23:54
    O.K. problem sorted, thanks again to all-grid was set to 11mm & I’d never bothered to change it ( I don’t always use the grid) soon as I upped the size it was fine.
    JJ.
