Home Forums Vinyl Cutter Discussions Mimaki Cutters why does my Mutoh SC-650 stop cutting & lights keep flas
  • why does my Mutoh SC-650 stop cutting & lights keep flas
    Posted by TAM on 12 August 2006 at 11:49
    Cutter will stop cutting & all lights will start to flash!
    TAM replied 19 years, 3 months ago 6 Members · 12 Replies
  • 12 Replies
  • autosign
    12 August 2006 at 13:55
    usually happens when there’s a crease in the vinyl causing a jam or something that is stopping the vinyl feeding through.
  • TAM
    12 August 2006 at 15:00
    good try but it is worse than that. cheers any way
    12 August 2006 at 15:15
    please elaborate on your questions and answers mate… it helps us all understand your problem better. which in turn will generate more replies/help.
  • TAM
    12 August 2006 at 17:08
    to start with ,after designing a job on the screen, i place it on the sheet grit ready to be cut,turn on the motoh,feed it with the colour i want & after the mutoh will perform the what i call the setting dance, then i will do the page set up & click on the design that i want to cut & press cut.
    The cutter some times it will just stop & all the lights will start flashing & some times it will stop half way.
    I tried cleaning the optical lenses & used a 1000mm x610mm piece of vinyl to prevent drag,tried lowering the acceleration & speed.
    & on my manual there is no troubleshooting section.
    regards
    tam
  • Kevin Flowers
    12 August 2006 at 19:31
    Tam
    what software are you using?
  • TAM
    12 August 2006 at 19:46
    Hi kev , I am using Easy sign (master V4.5 version),
    I removed it & reinstalled it again But the software looks more than fine to me .
  • Kevin Flowers
    12 August 2006 at 20:43
    TaM
    not used Easy sign but a couple more questions?
    Have you had the cutter working, has the fault just occurred
    What port set up are you using USB, parrallel or serial
    Are you using the an original Mutoh lead.
    Does Easy Sign have a dedicated driver for the Mutoh or are you using a generic one.
    My opion would be to look for a communication fault to start with, does the cutter do a self test cut.
    Do you have the manual as a quick read on the Mutoh website states there are different default settings to marry up with different software. It may be a case of trying each set up.
    http://www.mutoh.be/myDocuments/01/001/ … scengl.pdf
    Hope this is of some help
  • Frank Droog
    13 August 2006 at 14:15
    When someone tells me a cutter stops midway in a job my immediate suspision is he is plotting serial and has the wrong Handshake.
    With the wrong handshake, the plotter cant tell the computer to stop sending data when it buffer is full.
    Are you cutting Serial?
    If so, go to the Ports Icon in Windows Device Manager.
    Check properties of both Com1 and com2
    Make sure Handshake is set to either Xon/Xoff or Hardware.
    (actually check that it matches the handshake that the cutter is set to)
    Both Windows XP and 2000 default to a Handshake of NONE
    None will cause cuts to die in mid cut depending on the size of the job.
    If it screws up Sometimes at the start, sometimes in the middle. I might suspect loose cable.
    If USB, differant ballgame.
    frank at cadlink
  • autosign
    13 August 2006 at 16:38
    You might also have it set to "pause between pages"
  • TAM
    14 August 2006 at 11:56
    Hi frank , I checked the communications & all seems correct,It is still not cutting or stopping half way & all the lights will start flashing.
    It is also not performing the test or stops half way.
    Tam
  • Steve Maple
    28 September 2006 at 13:48
    make sure you have the left hand gripper locked in
    -it won’t know the page size otherwise
    also, they sometimes get confused -so set the cutting head back to front right and ‘origin’ then ‘enter’
    also if it stops half way it means the sheet length has been used
    -i think its 25 metres top whack
    -so if you are cutting something at 30
    -do it in 2 bits
  • TAM
    29 September 2006 at 09:02
    Thanks for the interest & i appreciate yourself trying to help.
    More than a month ago, got in touch (throu someone from this site)with AD Young & spoke to a very help full woman (Zoe) ,4 days after that i had a technician at my place and after a fast test he said ,it is the motor!!!
    He was spot on and now i am back on track.
    Also of interest,The same company offered me an insurance,so if any thing goes wrong, they will fix it for free. (not including wear & tear items)
    Thanks to all again
    TAM
