Home Forums Software Discussions Adobe Software why do i miss colour when i save from illustrator in eps?
  • why do i miss colour when i save from illustrator in eps?
    Posted by Scott.Evans on 7 July 2008 at 20:21
    if i run a jpeg straight from versaworks it comes out perfect.
    when i apply a cut line in illustrator and save it as eps. and then print and cut the file with versaworks it come out a good few shades of.
    can anyone see whats wrong
    thanks scott
    Nick Minall replied 17 years, 5 months ago 4 Members · 4 Replies
  • Ian Bingham
    7 July 2008 at 20:57
    Scott
    The colours change between EPS and JPEG when exporting, Try printing a colour swatch in both, you will be amazed at the difference
    Ian
  • Scott.Evans
    7 July 2008 at 22:07
    what is the best way for me to export into versaworks?
    with out the change in colours
    i need to export with cut lines.
    7 July 2008 at 22:14
    dont have illy here but from corel you have a choice in the eps export.
    apply icc profile should be off. if its on colours will change
    then the option send output as rgb or cmyk.
    i choose rgb as a rule for me it works a lot of people say it should be cmyk, try both see what works for you.
  • Nick Minall
    8 July 2008 at 07:42
    try placing ( file > Place ) the image in to illustrator then put your cut lines on and save as EPS 3, then put in to Versaworks.
    you can do the same ting in X3 as well.
    Nick
