Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters why do i get an uneven cut across width of machine?
  • why do i get an uneven cut across width of machine?
    Posted by Micheal Donnellan on 19 October 2007 at 00:01
    A bowed machine?
    I am getting a uneven cut across the width of machine. At the two ends it is fine but in the middle it wont cut. Have been doing short bits lately so not much notice taken until lately. Did a wide bit and WTF is wrong now was the words of the day. Had some clear film so but it in and cut from one end of machine to another. That’s when I could clearly see there was a major problem with the cut, as I could see the depth of cut easier. Both ends cut enough to cut paper backing on vinyl the middle was a bare scratch and completely missing in one patch. Its almost the machine had a bow in it?
    Anyone have an idea whats up?
    Andy Gorman replied 18 years, 2 months ago 3 Members · 4 Replies
  • Andy Gorman
    19 October 2007 at 00:04
    First thing I would look at is the cutting strip.
  • Micheal Donnellan
    19 October 2007 at 00:13
    not sure if its that I douth it, will give better check tommorow, might get calipers out and see what the hell is going on.
    19 October 2007 at 00:22
    very rare but the ribbon cable to the head could have a make and brake in it. as you say its completely missing at one point.
  • Andy Gorman
    19 October 2007 at 00:47
    Hmmm, cutting strips usually wear thin at the 0,0 origin rather than the middle, so it probably isn’t that now I think about it.
    I’d be inclined to take the cover off and have a good look and a good clean and lubricate.
