Home Forums Vinyl Cutter Discussions Roland Cutters why am i getting a fan error on roland cx24 please?
  • why am i getting a fan error on roland cx24 please?
    Posted by Matt Boyd on 16 March 2006 at 17:41
    hi all, my roland is now displaying fan error after nearly every run. i have to switch it off and then switch it on again to get it to cut again. any ideas? is it a case of just needs a service? only trouble is the nearest guy to service it is about 2 1/5 hours away from me!!! has anyone had this trouble before?
    thanks guys(and gals!)
    Matt Boyd replied 19 years, 9 months ago 4 Members · 9 Replies
  • 9 Replies
  • Tim Painter
    16 March 2006 at 18:01
    Is your roland on a desk or on a stand? Just asking the obvious first as the fan is located underneath the unit. Can you hear the fan functioning when you turn it on?
    Tim.
  • Matt Boyd
    16 March 2006 at 18:28
    hi tim, its on a stand of sorts!! its one of the big plastic stands for tools you stick in your garage, ones you find in b & q. it has cut outs underneath so theirs plenty of ventelation. it did it a few times last year but these past few months its been getting more and more common!
  • Matt Boyd
    16 March 2006 at 18:29
    oh yes, sorry, i can hear the fan when its switched on.
  • Peter Shaw
    16 March 2006 at 19:53
    Try brushing out any accumulated sh*t in and around the fan.
  • Matt Boyd
    16 March 2006 at 19:54
    cheers peter, does that mean taking the casing off then or is their an easier way?
  • Peter Shaw
    16 March 2006 at 22:16
    I don’t know the detail of the CX24 but if you can clear the fan with a paint brush and maybe an air duster or vacuum cleaner, it may help.
  • Matt Boyd
    17 March 2006 at 02:06
    cheers peter i’ll try that tomorrow, hopefully its just dust or something, hope so, as i bet a new fan or whatever the problem is will be expensive!!!
  • Marko
    17 March 2006 at 08:52
    My cutter blew it´s fan with a smokecloud the other day. Opened it up, took the fan off and replaced it with a new standard fan that I got from a electronic parts dealer.
    Cost me 8€ and took about an hour.
    Works ok, even a little quiter than the original…
  • Matt Boyd
    17 March 2006 at 14:02
    hi marko, wow smoke clouds!!!!!!!!! 😕 mine is just reading fan error at the moment, but means the machine won’t function at all unless i switch it off and then back on again!! so not sure if its the fan or something else?? i’m going to try cleaning the fan area so hopefully that’ll work! 8€ is good for a fan!!
