Home Forums Software Discussions Flexi Sign Software why am i getting a ‘caught exception error -6’?
  • why am i getting a ‘caught exception error -6’?
    Posted by Arthur Raynor on 9 May 2008 at 09:09
    Using Flexisign Pro 8.1 and while trying to RIP & Print, I am now suddenly getting a ‘caught exception error -6.
    This just started 2 days ago.
    Only happens when I use my HP Z2100 wideformat printer.
    I can print as normal but cannot use RIP and Print.
    Error message only happens with the HP Z2100 and not with my other 3 Xerox printers.
    Have reinstalled Flexi with no luck.
    Flexi email support suggested in flexi edit menu> preferences> tools tab> select rip/print on the left> uncheck connect to Production Manger using tcp/ip. That did not help. They also suggested clearing Prefs. but I am not sure how/where to do that.
    Help!
    Arthur Raynor replied 17 years, 4 months ago 3 Members · 6 Replies
  • Arthur Raynor
    9 May 2008 at 20:26
    By way of a further update, I installed my Flexi on my wife’s laptop and it works fine.
    Does the RIP & Print with no problems.
    Help #2
  • DaneRead
    16 May 2008 at 15:51
    go to start … all programs….SA produciton suite.. preferance manager.
    select factory settings then click load.
    clearing preferences has worked for me on another issue i had. everyone says it helps alot.
    worth the try.
  • Arthur Raynor
    7 August 2008 at 22:51
    message duplicated
  • Arthur Raynor
    7 August 2008 at 22:52
    quote DaneRead:
    clearing preferences has worked for me on another issue i had. everyone says it helps alot. worth the try.
    That did not work but I solved the problem (after a few months.
    I had TCP/IP selected in the use Production Manager preferences.
    I connect via USB so when I created a new setup for my printer and selected USB instead of TCP/IP for Production manager, I can now Rip and print and no longer get the exception error.
  • Simon Polakof
    8 August 2008 at 04:54
    Have you tried reinstalling the rip?
  • Arthur Raynor
    8 August 2008 at 13:52
    quote Simon Polakof:
    I did that in my early troubleshooting.
    But as I mentioned in my last email yesterday…the problem is solved.
