Home › Forums › Sign Making Discussions › Vinyl › Who supplies clear static cling material?
Posted by Marcella Ross on 6 April 2006 at 19:42Who supplies clear static cling material? I’m looking for clear material that is suitable to put vinyl text on reverse for a rear windscreen. Customer wants something removeable so that the name and number is only on the car when she’s working.
thanks,
Marcella
Peter Shaw replied 19 years, 7 months ago 12 Members · 25 Replies -
Hi think Hexis do it – I take it the plan is to print onto it?
No Dawn… it’s just being vinyled, it’s only a name and number… and there’s only 2 needed!
I take that kebabbed eyeball is causing you problems …… :lol1:
If you go to http://www.hexis.co.uk it is in their price list. I’ve never used it personally, but no doubt others out there have.
Marcella
I’ve just found another post which says the Europoint stock it so you could contact them tomorrow. I’m just wondering, though, how well it will survive being regularly applied and removed.
Dawn
spandex do it have only printed on it haven’t put vinyl on but I can’t see why it wouldn’t work on a stationary vehicle, a bit off the wall but would ordinary cling film work 😳
quote Phill:Europoint supply static cling – it’s called Penstick. 😀
yep thats what i buy…but i dont know if you’ll be going down the same road as you were with the mask vinyl marcella…im sure they only sell it in minimum sheet amounts 😕
thanks.
nik – you’re probably right about the minimum order knowing my luck! 😕
I’ll give them a bell tomorrow. I take it this stuff is suitable to put a vinyl telephone number on?
Marcella
Dorotape sell clear static cling vinyl..reasonable too..Jon
i have a roll here !!! i got it cos a customer wanted to have self cling stickers, soo, i stuck vinyl to the rear of it, cut in reverse, but you try getting the app tape off without stretching the stuff, it doesnt cling to its liner very well ! i told the guy it wasnt worth doing, though i gave him a price, just found it very awkward, maybe i’ll have another play at it, i dont recall if i wet the app tape,
so far as i know, it’s only really meant for printing onto.
😕 mmm ….. that’s what concerned me Hugh… if I could easily put vinyl on it…
it was a long time ago when i tried it, and i know alot more now than then ! so i might try it again, not sure how i went about it back then !!
you were right enough Nik. Europoint sell windowstick which is fine for applying vinyl to, as they told me. But minimum order of 50 sheets at 700 x 1000mm 😕 Not too expensive but it’s not something I’m likely to use for a long time again. 1/2 sheet would do me so I’d have a shed load of it left over. I doubt my customer would want to pay for 50 sheets just to have their number on their rear windscreen.
I’ll try somewhere else that’s been recommended.
Marcella
Did you find out whether it would stand up to being constantly applied and removed?
Dawn
Hi Marcella
try All Print Supplies 01753 696977
they sell it by the roll (approx £100) both as white and clear, we use it a lot particularly the white, put it thru our Roland Soljet and bobs your uncle.
quote John Roddick:Marcella
Dawn
I’d already told my customer that it wasn’t really recommended that it’s removed and applied constantly. But she’s only likely to remove it when her hubby is driving her car. She’s not too concerned.
I can’t remember who I got mine from, either Grafityp or Victory Design, only got 5m, wasn’t expensive either.
Update: Just looked at roll, it’s on a Victory tube, so I guess that’s where it came from!
Marcella,
if you can manage to do it with static cling, i have a roll here tell me how much you need & i’ll send it upto you.Kev
Thanks kev.
I’ll let you know what my customer decides.
Marcella
Hi Marcella
What about a more rigid sign and suction cups???
Just an idea if it’s a 1 off……..
Tim.
It’s a very small part of a small job anyway Tim. i doubt it’d be worth it.
It’s one of ‘those’ jobs. Only reason I’m bothering with it is because she and her hubby are regular customers. It’s always small jobs, but fairly frequent.
I’m sure she’ll settle for what i offer her! 😉
