Home Forums Printing Discussions General Printing Topics Which material to use when making a pop up display
  • Which material to use when making a pop up display
    Posted by Andrew Blackett on 4 February 2009 at 20:06
    Good Evening everyone,
    Having used the grafityp popup material with dodgy results I’m just wondering what material you use for making pop up exhibition displays.
    We’re using a versacamm and will be laminating but just wanted a recommendation really.
    Best wishes
    Andy
    Andrew Blackett replied 16 years, 10 months ago 9 Members · 20 Replies
  • 20 Replies
  • Ian Jenkin
    4 February 2009 at 20:23
    Evening Andy,
    We use, believe it or not, a black out banner material from Spandex (i think) – We usually supply without lamination, but it gives a very crisp looking matt finish.
  • Andrew Blackett
    4 February 2009 at 20:36
    Hi Ian,
    But surely that wouldnt be rigid enough? I’m working on the assumption that it’ll be semi rigid.
    Andy
  • Ian Jenkin
    4 February 2009 at 20:38
    On its own, it would be, but the ones on a stand with the backing stand pole thingy, its ideal.
  • Andrew Blackett
    4 February 2009 at 20:39
    Think we might be on cross purposes here buddy, I’m talking about pop up’s and I might be reading it wrong but I think you are discussion roll up’s?
    Andy
  • Ian Jenkin
    4 February 2009 at 20:41
    Bingo, sorry fella! (-)
  • Andrew Blackett
    4 February 2009 at 20:43
    No worries, thought it sounded too easy to be true 😉
    Andy
  • Pryam Carter
    4 February 2009 at 21:18
    Hydrosol is a pretty good bet for pop ups, they do 2 types. The thinner gram for rollers and the thicker for pop ups.
    We get good results with this material.
  • Andrew Blackett
    4 February 2009 at 21:26
    Assuming its ok for versacamm from some basic google searching but can you recommend a supplier mate?
    Andy
  • Russell Huffer
    4 February 2009 at 22:23
    I have used 300micron litestop from B&P printed on my Grenadier and laminated with 80micron for PopUps these have come out really nice, the B&P material is good quality and reasonably priced.
    Russell.
  • Paul Munford
    4 February 2009 at 22:56
    We do a few pop ups.
    I have had the best results with Kentmere’s K.Opaljet 125 (for the curved ends) and K.Opaljet 300 (for the main panels) from robert horne. Ive tried allsorts and this is the business. More expensive than some, but you can be sure of a tried and tested quality product.
    Paul.
  • Owen Lees
    5 February 2009 at 00:43
    Seconded, Opaljet – it works every time and is dead easy to work with.
    Oo
  • Russell Huffer
    5 February 2009 at 07:37
    I have used miles of Opaljet for exhibition work printed on my HP Designjet and it is the best product in my opinion but as stated you will need the Opaljet P to print with solvent and i have never tried this only the B&P stuff which gave a good finish and i have used it next to Opaljet on the same stand and it does print flatter.
    Russell.
  • Pryam Carter
    5 February 2009 at 09:12
    I get mine from Amari Digital.
  • Jamie Wood
    5 February 2009 at 10:11
    DoroTape do Hydrosol. We use this with excellent results on a JV3. Tried
    OpalJet, but I find it looks dull compared to HydroSol.
  • Mike Grant
    5 February 2009 at 21:23
    I have only done one and I used Hexis with good results. looked good laminated.
    6 February 2009 at 10:17
    i had to drop opaljet as there was to many flaws in the solvent surface they may have improved since, now use image perfect nice colours and perfect print surface.
  • Andrew Blackett
    6 February 2009 at 18:35
    Apparantly the opaljet stuff is being upgraded in a couple of weeks with a brand new solvent surface. The guy I spoke to sounded quite enthused by it and is going to send a sample once they have them.
    In the meantime Europoint (should of made that my starting point really as they are one of my main suppliers 🙄 ) do the two types of hydrosol (roll and pop up) but can anyone tell me what profiles they use for hydrosol or where to download.
    Cheers,
    Andy
  • Pryam Carter
    6 February 2009 at 20:21
    Hydrosol don’t have any profiles, they recommend that you print using a matte profile. Try a few different ones and see how you go.
  • Andrew Blackett
    6 February 2009 at 20:30
    Cheers buddy
    Andy
  • Andrew Blackett
    19 February 2009 at 19:16
    UPDATE – the guy came in today with the sample of the all new opaljet solvent. Aparantly the coating has been reworked to give far better results. Had a play with this one, hydrosol and grafityps pop up.
    Results are as follows;
    Grafityp – Media surface is quite "rough" to the feel, print quality not good, colours flat. Once printed and laid flat the media bows up on itself.
    Hydrosol – Media surface very smooth to touch, print quality good, dries promptly. Once printed stays perfectly flat
    New Opaljet – Media surface very smooth, print quality good, dries promptly (not quite as quick as hydrosol) colours very vibrant, lays perfectly flat
    Its going to be officially launched at SignUK but these early field test rolls are proving very good indeed. I’ve been left with the bulk of a 20m roll to do re-do our display in the reception area as a beta test. Will post the full pics when done but its looking good.
    Would say theres a big imrovement on the grafityp one we were using but I guess you dont know theres a problem until someone shows you the error of your ways. Found this again when comparing the opaljet 165 micron roll up against the stuff I got from victory (euromedia I think) again the euromedia had a really rough feel in comparison to the opaljet.
    Andy
    quote Andy Blackett:
    Cheers,
    Andy
