Home Forums Sign Making Discussions Traditional Which masking vinyl for use on painted walls
  • Which masking vinyl for use on painted walls
    Posted by Tim de Beir on 12 August 2013 at 11:44
    Every now and then I have to paint some signage in a museum.
    At this moment I use Avery Signmask Blue with medium tack application tape, but I find it hard to remove the application tape, without removing the signmask stencil also.
    I was wondering what you guys use as stencil vinyl, to paint lettering onto painted walls…
    Tim de Beir replied 12 years, 4 months ago 3 Members · 3 Replies
  • John Singh
    12 August 2013 at 12:28
    I use Oramask 810 fro Orafol
    You may have the same result though as that is the way mask is made
    It isn’t really made to stick down permanently (I know that’s obvious).
    Other vinyls do have better tack hence easier to remove application tape
    Mask is also softer which means it doesn’t ‘snap back’ when removing from wet paint which causes a light spray of paint to hit the surface
    12 August 2013 at 12:51
    I’ve been using Avery signmask for the blast cabinet & it works well so rather than changing what you know is a good mask have you thought about trying a different application tape?
    I tend to use the clear type tape from orafol for anything that I think might cause problems with application tape removal as I find it comes off a lot easier than the paper tape, been using it with the gray avery signmask without any problems.
  • Tim de Beir
    12 August 2013 at 19:12
    okay thanks for the advice!
