Home Forums Sign Making Discussions General Sign Topics which adhesive is best?
  • which adhesive is best?
    Posted by Marcella Ross on 10 January 2007 at 09:55
    I’m sticking 5mm foamex to 5mm foamex, which adhesive would be best for the job? It is for hanging strips so it will be taking the weight of the sign.
    I had good stuff before ………. but can’t find it nor can I remember what it was called. It was a 2 part stuff …….. 😕
    TIA
    Marcella
    David-Foster- replied 14 years, 5 months ago 9 Members · 13 Replies
  • 13 Replies
  • David Lowery
    10 January 2007 at 10:06
    Tensol?
    I always tend to put some countersunk self tappers through as well because I believe in belt and braces stuff 🙄
  • Graeme Harrold
    10 January 2007 at 10:46
    Take a look at the Loctite web site as they have an excellent online product selector based on application http://www.loctite.co.uk From previous experience Loctite are extremely helpful and can do onsite product demonstrations.
    If you get it right, an adhesive will provide a fixing strength well above that of mechanical fastener’s (bolts screws etc), however due to curing times a couple of screws are necessary to 1. prevent initial peeling and 2. hold the pieces in contact until full cure strength is achieved.
    Hope this helps
    10 January 2007 at 10:52
    many thanks 😀
  • Fred McLean
    10 January 2007 at 11:26
    Give some plumbers pipe cement a go
    It’s a bit smelly though!Open doors for plenty ventilation!!
  • Andy Gorman
    10 January 2007 at 11:30
    Yes, the pvc pipeweld adhesive from diy shops is the best I have found. If you can find Osma brand, it comes in a tin with a brush in the lid, then all the better.
    10 January 2007 at 11:35
    Thanks for the info, I’ll give it a go.
    Marcella 😀
  • David Rogers
    10 January 2007 at 13:30
    Loctite do a reinforced superglue.
    Ordinary super glue sticks PVC together amazingly well – and if you used enough of it to just coat the surfaces it’s impossible to separate them.
    I normally put a bead down any PVC hanging strips & add it a few screws for added peace of mind – not had a problem yet.
  • Graeme Harrold
    10 January 2007 at 13:38
    Probably would not go far wrong with "tough as nails". Doesn’t have the associated vapor problems and if you apply a thin film to both mating parts it will be pretty strong. As with any adhesives their strength lies in the amount of BONDED surface area. Any deformation in the material could result in small voids that do not stick thus reducing the CONTACT area.
    Super glue although strong does have the problem with being brittle esp with plastics
    10 January 2007 at 14:36
    The pipeweld stuff already mentioned I’ve used before ……… for plumbing right enough, not signs. But being familiar with it, I’ll give it a go.
    As for Superglue ……… I’m rarely successful with that ……… usually stick my fingers together 😮
  • Fred McLean
    10 January 2007 at 14:38
    Sticks PVC pipe!
  • Russell Spencer
    15 January 2007 at 12:43
    have a look here
    http://www.brettmartin.com/semifinished … sives.aspx
    tensol has THF in it but we have never had much success, 2 part epoxies seem the way to go but as a previous poster said I always put a couple or three screws through hanging strips, just to make sure.
    15 January 2007 at 13:19
    I use to use Euro-bond for most of my adhesives, they supply adhesives to all sorts of industries including the sign industry. Always found them very helpful in ensuring I had the right glue for the job. The penloc was very good for this sort of thing if I remember rightly.
    http://www.eurobond-adhesives.co.uk
  • David-Foster-
    6 July 2011 at 13:11
    Never let it be said I don’t search :lol1:
    An old thread, so seeing if anything better has come along since 4 years have passed.
    Same as Marcella, bonding foamex sheet to foamex sheet. Pipe adhesive sounds good, tin with a brush in it. Anything better, evo-stik contact? I want to get it from B&Q rather than order and deliver please. Will be hung off the wall from the back sheet so I may be able to put a few screws in the back but nothing on the front face.
