Home Forums Sign Making Discussions Vinyl Where can I get smooth Blackboard vinyl?
  • Where can I get smooth Blackboard vinyl?
    Posted by Paul Rollason on 10 June 2004 at 16:14
    Hi all
    I ordered some blackboard vinyl from vinyl corp but it was not what I expected.
    I expected it to be a smooth mat black like if you spreyed blackboard paint.
    What I recieved textured very similar to a vinyl I used in mold making to get a non skid surface.
    Paul R
    Bill Dewison replied 21 years, 6 months ago 3 Members · 5 Replies
  • Nigel Fraser
    10 June 2004 at 17:54
    As far as I know paul, you can’t get a smooth vinyl for that application – the reason being that “Vinyl” by it’s make up is a fairly soft material and chalk needs to have a slightly abrasive surface to kind of sand it away as you write. Vinyl of a smoothish texture would mark/wear out too easily so they make it exagerated kind of sand paper textured so it will last.
    I may be wrong but thats what my impression is anyhow !! I assume you read the previous numerous posts on this subject …..?
    sorry, not much help really I guess 😉
    Nigel
  • Paul Rollason
    10 June 2004 at 19:13
    Thanks Nigel
    I,m sure I’ve seen this less textured black board effect on signs in the past.
    I will just have to keep phoneing suppliers and getting samples.
    As soon as I find what I am looking for I will let you all know.
    The quest continues.
    I suppose I could spray Blackboard paint onto a masked off portion of the sign.
    Paul R(Mackerelbus Design)
  • Bill Dewison
    10 June 2004 at 19:15
    I had a sample of some blackboard vinyl from Hexis, and that was a little smooth. Still a stippley kind of texture, but smoothish 😕
    Tried a couple of methods for blackboards now, and I’ve found spray on (as suggested by Chris at FluidEdge) works the best for me 😀 Really easy to apply as it just sprays on, and relatively cheap as well, about £2.50 a tin.
    Cheers, Dewi
  • Paul Rollason
    10 June 2004 at 19:37
    Cheers Dewi
    I think that is the way to go
    What with the vinyl I go costing £12.50 a metre an all 🙁
    How well does it stick to vinyl, do you have to prepare the surface etc
  • Bill Dewison
    10 June 2004 at 19:59
    I haven’t tried spraying it on vinyl yet to be honest, I’ll have a lash at that tomorrow 😀 I just spray it onto foamboard, then bright coloured or matt white vinyl on it in various designs.
    I am trying out some Aboard designs at the moment, with blackboard inserts, so it’ll be put to the test as to whether its as hardwearing as the paint on version. I was told the blackboard vinyl can go shiny after a while, and it’d spoil the effect of the signs I’m making atm.
    Also, Nigel (CreativeSigns) was discussing the merits of a thin laminate material coated for blackboards. Again, something I want to try out, but then I like trying everything and there are only so many hours in a day 😀
    Cheers, Dewi
