Home Forums Sign Making Discussions Neon, LED, Lighting where can i get curved Illuminated Fascia signs?
  • where can i get curved Illuminated Fascia signs?
    Posted by Glenn Sharp on 17 October 2007 at 10:29
    Could anybody point me in the right direction for the above.
    Customers premises is on a rounded corner with a fascia width of about 6 metres……any advice greatly appreciated whether it be aperture cut aluminum face, flex face or whatever any body can come up with
    David Rowland replied 18 years, 2 months ago 3 Members · 3 Replies
    17 October 2007 at 12:12
    we had a customer in the past that had a long fascia bending around a corner. They did not want to pay allot (as most customers don’t these days) anyway… we sheets the wall with .5inch exterior ply, because the wall was sandstone and not very flat. we then faced it with 2mm aluminium with countersunk holes all located within an inch of the parameter of the panels. once everything was in place, we then fitted a flat strip/bar of aluminium all around the face/sides to give it a finished look and to hide all the screw fixings of the sheets to the wood.
    i also found working the sheets from the middle of the building outwards helped keep it aligned better. working from one side normaly results in the panels riding up the further you get around. also… pin the panels into place as you work. dont just fix one up and pepper it with screws… get all the panels up with as little fixings as possible. then if everything is running correct, secure in place and repeat with your facing panels.
    hope that made sense? 😕
    edit… just read heading again its illuminated curved fascia??? 😳
    well we did have a over hanging spots if that helps :lol1:
    i recon going the flexface route is the best "long term" bet…
    maybe call kestral signs or signbaseuk for more help on that…
  • Glenn Sharp
    17 October 2007 at 13:10
    lol….thanks Rob….I was reading through wondering when you were going to mention the illumination…
    Thanks ..I’ll give Kestrel a try
    17 October 2007 at 22:16
    http://www.uksignboards.com/viewtopic.p … 585#239585
    edit: i just noticed the word illuminated… oh stick some spot lights on it lol
