Home Forums Vinyl Cutter Discussions Mimaki Cutters where can i get a blade holder for an old SC-650?
  • where can i get a blade holder for an old SC-650?
    Posted by Alex V on 17 August 2009 at 08:50
    I realise this is an old cutter but we’re now onto our last blade holder (roller bearings have given up the ghost on the last two) and i’d like to source a few spare holders however google is only giving me blade suppliers and each time I ask if they can provide blade holders the answer is no. Anyone able to point me in the right direction ?
    *edit* Should have said i’ve already spoken to Edward Mathias re smart knives but was after a traditional holder as well if possible.
    I did use the search function before asking and again my apologies if i’ve missed something obvious 🙂
    Alex
    Colin Crow replied 16 years, 4 months ago 5 Members · 11 Replies
  • 11 Replies
  • Chris Windebank
    17 August 2009 at 08:55
    sorry, are you referring to the cylindrical plastic object that holds the blade itself? or the clamp on the machine
  • Brian Hays
    17 August 2009 at 08:57
    You could try Art Systems in Nottingham (0115) 9380 380. They distribute Mutoh’s.
  • Alex V
    17 August 2009 at 09:17
    Sorry Chris I should have been clearer, it’s the cylindrical plastic blade holder with metal top adjuster that you insert the blade and spring into, this then fits into the carriage/clamp on the cutter.
    Cheers Brian i’ll give them a call now and report back 🙂
  • Alex V
    17 August 2009 at 09:44
    Brian you were spot on, many thanks 🙂
    They had one in stock though at £90.94+VAT and £8 P&P I think the Smart Knife option makes more sense for me. I’d rather buy another two spare smart knives ‘just incase’ and spend the other £50 on 5 blade swaps than spend £90.94 on a blade holder alone.
    Thanks 🙂
    Alex
  • Colin Crow
    17 August 2009 at 13:43
    Spandex sell these at around the same price and also the envision blade holder is identical if you can find one cheap?
    But to be honest, since using the smartknife I wouldn’t go back to standard blades now as the quality of the "cheap" blades is so variable and the original blades are ridiculously priced.
    Colin
  • Tobias Redig
    17 August 2009 at 13:58
    quote Colin Crow:
    I was quoted £550 for just the knife holder for an Envision375. I checked that with the weight of the holder and the current gold price and came to the conclusion that it was literally worth it’s weight in gold…
  • Colin Crow
    17 August 2009 at 15:12
    In that case I would buy the Fasttrack 650 holder for your envision – it must be a bargain! 😀
    Colin
  • Tobias Redig
    19 August 2009 at 06:17
    So does the SC-650 knife holder fit a Gerber Envision 375? They look rather similar.
  • Colin Crow
    19 August 2009 at 06:38
    The ones I had were fully interchangeable and worked fine so I doubt anything has changed much.
    Colin
  • Tobias Redig
    19 August 2009 at 10:08
    £90 for one of those, quite alot cheaper!
    This seems to be the norm with Spandex though, everything is usually *alot* more expensive when it’s branded with a Gerber logo.
  • Colin Crow
    19 August 2009 at 10:12
    To be fair, the envision holder is a posh anodised aluminium body as opposed to the Mutoh plastic one, although probably not worth the £400+
    Colin
