if you are stuck then clean up as best as possible apply a 6mm strip of vinyl over the cutting strip a little polish with mrsheen to make it slip better.
Give Roland a ring – they may not have the 5000 ones available anymore but they normally have the ones for the PC600 and you can often improvise and use the ones from other machines.
I needed some for our PNC1000 and they only had the PC600 ones, which are thinner but still work OK.
Please note:
