Home Forums Sign Making Discussions Vehicle Wrapping whats the correct way to deal with recesses on van?
  • whats the correct way to deal with recesses on van?
    Posted by del on 24 November 2005 at 13:22
    Hay Guys.
    I have a van to do that ha 2 pannels, and the letters go all the way across the side of the van.
    whats the correct way to tackle this, is it to lay the letters over the recess and then work them in with a hair dryer or is it to work them in as im laying?
    The pannel recess’s are not to deep, but there all the same 🙂
    thank for your help guys.
    Martin Pearson replied 20 years, 1 month ago 5 Members · 5 Replies
  • Andy Gorman
    24 November 2005 at 13:58
    You could heat it into the recess if your vinyl is up to it, but it may distort the edge of the vinyl a bit. Alternatively, work it in but remember that the return will take a bit of spacing away from your lettering.
  • del
    24 November 2005 at 14:56
    Thanx Andy, cool 😀
  • steve geary
    24 November 2005 at 16:33
    yeah.. what Andy said…
    I used to put it in the recess as i go, but the last few i did dry and I went straight over, then worked it in with a bit of heat before i removed the tape. then finished it off after tape was removed. It seemed to work the best for me.
    this was with cast vinyl and only one layer, but i’d probably do the same with multi layers.
    steve
    24 November 2005 at 16:52
    Del If its only a single recess, and no double corners I would work it in as you go. if its a deep recess I would also give it a bit of heat to finish.
    This is the demo that rob did that explains how you work it in if thats the way you decide to go
    http://www.uksignboards.com/viewtopic.php?t=2652
    24 November 2005 at 17:55
    One other thing to take on board Del is that a hairdryer is no good on its own if you want the vinyl to stay in place once fitted in the reccess. They dont produce enough heat, I’m not very good at fitting vinyl with a heat gun so I always use a hairdryer to fit no matter what I’m doing. Once fitted I will always go back over it with a heat gun, normally twice.
