Home › Forums › Sign Making Discussions › Graphic Design Help › what way can i crop this layout?
Posted by Nicola McIntosh on 8 February 2007 at 12:31hi folks 😀
im stuck on trying to crop the attatched file in photoshop..it only crops in a rectangle..i want to have it cropped with the same margin all the way around..i would have done it in signlab but it leaves a white background 😕 any help appreciated 😉
Nicola McIntosh replied 18 years, 10 months ago 6 Members · 12 Replies -
yeh like yours dave but without the white background 😀
tried your method andy and i got stuck, but i will need to know how to do it..cause ive got loads of similar pieces to do 😕
The method I gave does give ‘no background’ but it appears white because I exported as a jpg. The width of your border can be set when you get to the ‘expand’ part. All this is done in the select drop down menu.
quote Andy Gorman:The width of your border can be set when you get to the ‘expand’ part. All this is done in the select drop down menu.
got that far andy..but stuck on the erase background bit 😕
nik, i might be wrong here but…
you are wanting to select all the yellow.
cut it from image.
paste it into a new background, possibly clear or whatever colour?
then create a black halo on the yellow text that you can increase and decrease the spread? -
quote Robert Lambie:nik, i might be wrong here but…
cut it from image.
then create a black halo on the yellow text that you can increase and decrease the spread?its going onto a black & cream background….so i need to dodge the cream and crop the black in as much as i can 😕 hope u understood that too… 😉
Nik, once you have expanded the selection to the required width, invert it so the background is selected instead, then use the eraser tool. (It looks like a rubber!)
Is this what you mean?
ripped it to a vector & outlined it.
Easily imported & converted to a transparent gif, and/ or use the wand to select the background then copy & paste over your other image.
oh what a day ive had 😮 thanks for all your help…..the penny finally dropped when i done the cropping in signlab….. 😳 i had saved as a jpeg..and yes i got a white background 🙄 silly me forgot to export as a ai. im not a fan of photoshop as there is so much to learn..but i need to keep at it…..and andy i know what a rubber looks like 😉
Nik, cropping and clipping are 2 different things, I think you need to contour cut in signlab, then if needed , clip
quote Peter Normington:Nik, cropping and clipping are 2 different things, I think you need to contour cut in signlab, then if needed , clip
Peteroh peter im in total brain dead mode now…. 😕 photoshop has worn me out today i think 😉
