Home › Forums › Sign Making Discussions › Vinyl › what vinyl can i put on an inflatable boat?
Posted by JimmehF on 3 June 2008 at 22:04Hi everyone, can anyone suggest some vinyl i can use on an inflateable boat? Its a proper sea one with an engine on it, just need advice really on what i can use, and also is there any steps to prepare the surface?
thank you
JamesRichard Urquhart replied 17 years, 4 months ago 7 Members · 8 Replies -
I dont have any direct experience, but I would suggest using proper truck curtain vinyl, I cant see why it wouldn’t work, salt, water, wind, heat and cold don’t appear to effect curtain siders.
Thats a great idea, and yes they do get battered by the elements!
Can you recommend a good supplier? My local suppliers only do standard vinyls and banner vinyls, just had a quick look on victory website theres nothing there so maybe i should give them a ring in the morning.
Thanks 🙂
James -
Not sure but a think all print supplies do a truck vinyl, and a would think spandex do as well,
peter -
quote barney:roll on some screen ink through a mask
thin with acetonethats what i would do, but it depends what ink you use, they dont all work, most flake and rub off, i would try applying to a small area of the boat first just to see if it grips, also adding rigid vinyl thinners helps it along also 😀
Im looking for something similar for boat fenders. Managed to use std 5-7 yr vinyl and it sticks well, but Im looking for something harder to remove and a mask with ink could be the way to go. Just contacted an ink supplier and am waiting for a response.
As to RIB names, I have used cast with absolutely no problems providing what you do is not on a high ar$e traffic area, as the tubes on smaller ribs double up as seats!
We find that on some things the ink is not durable enough – especially when it is subject to a lot of rubbing…so we use a mask and spray with vinyl upholstery paint (talk to your local automotive shop) and that works very well
Hi all fitted a small rubber tender boat a while ago using APA truck vinyl and its worked a treat
rich
