Home Forums Sign Making Discussions General Sign Topics What type of Javelin cutter to buy?
  • What type of Javelin cutter to buy?
    Posted by Ruairi O'Boyle on 7 December 2010 at 21:28
    I want to buy a Javelin Cutter and had been set on a 3m one. Today i spoke to someone who recommended going for the 1.5m or 2m options as they are more easily used.
    They also suggested looking at the evolution. Now I am not sure what to go with. I basically want it to trim prints and corriboard/forex. What do you guys recommend? I know this topic has been done before but not necessarily addressing the best size as far as I can see! If I am wrong, sorry and hopefully some of you will point me in the right direction.
    Ben Hansen replied 15 years ago 7 Members · 11 Replies
  • 11 Replies
  • David McDonald
    8 December 2010 at 13:48
    Hi Mate
    We’ve had a Javelin for years, think its the 3m version, only ever rated it as OK until we bought the ‘big bench’ to go with it. This means you are cutting into a channel rather than onto the work surface, ie, better cuts and longer lasting blades, plus easier to align the cuts and much quicker. One of the lads in the workshop now commented its the best bit of kit we’ve ever bought!
    So consider the bench as only then do you get the best out of a Javelin.
    Macky
  • Ruairi O'Boyle
    8 December 2010 at 14:19
    Cheers David Ill bear that in mind!
    8 December 2010 at 14:40
    We spend more time with the 1.5mtr then the 3mtr jav, the smaller one is easier to use.
  • Ruairi O'Boyle
    8 December 2010 at 15:52
    Cheers Dave, thats what the supplier reckoned
  • Chris Friggieri
    8 December 2010 at 16:02
    Hi we were going to buy the two mtr one but the supplier (JAG) had the 2.1mts which is the same price.
    Since many forex boards are 2mts you can cut a sheet in a single cut otherwise, the javelin is fantastic minimum pressure and sharp edges
    Chris
  • Ben Hansen
    8 December 2010 at 18:00
    Hey guys, im waiting delivery on my Javelin Big Bench tomorrow, ive lived without one for years but always wished i had one after using one in my first job. im fed up of using a steel ruler and blade! i went for the 3m so it can take all sizes of boards. il let you know how i get on with it once its all set up!!! i cant wait!! just hope i get some work in so i can use it! 🙂
  • Matty Goodwin
    8 December 2010 at 19:18
    Only problem I ever had using the Javelin on foamex is the ammount of static it holds!
    After cutting you can get a nice little belter from it when you lift it up!
    Great bit of cutting kit tho!!
    Matt
  • Ruairi O'Boyle
    8 December 2010 at 19:20
    Matty
    What size of cutter do you use?
  • Matty Goodwin
    8 December 2010 at 20:23
    It was the 3mtr
    We used it to cut down prints that were fed through the laminator, straight on the bench.
    Most of the time mounted on foamex.
    Maybe the laminator caused the static….????
    Matt
  • Jason Xuereb
    9 December 2010 at 04:23
    I’ve got the 2.5m with the side lifting things. It isn’t the big bench but the lifting things that are on it. I’ve bolted these down to my bench with a glass top.
  • Ben Hansen
    10 December 2010 at 21:04
    Hi Guys, just thought id update you on my cutter! the final part was delivered today and it is FAB!!! it has saved me a real ball ache already and iv only used it for a couple of hours!! i held back spending the money for so long but im so chuffed i went ahead with it!!! a must have!
