Home Forums Software Discussions General Software Topics what software for pc-600 ?
  • what software for pc-600 ?
    Posted by widget on 10 November 2004 at 22:15
    Can anyone recomend some half decent but fairly cheap software to use with a roland pc-600 print and cut ?
    the software i have does not support print and cut and would like to upgrade to something with a few more features,i am using corel draw at the moment but it does not contour cut acurate for me 🙁
    Is there anywhere i can download the software for the pc-600 or do you only get it when you buy a new cutter?
    thanks
    widget replied 21 years, 1 month ago 5 Members · 11 Replies
  • 11 Replies
  • David Evans
    11 November 2004 at 11:47
    Roland did supply both a Windows driver and ColorChoice (which is a PostScript solution).
    The windows driver you can download from
    http://www.rolanddga.com/support/file.A … &ST=&ft=11
    But they only send out ColorChoice on a CD, so need to see if anyone has a copy. Latest version I think was 4.1
    These are basic drivers from Corel, you can print and cut and do simple spot color work.
    If you want to get really clever with the PC-600 take a look at Signlab with the thermal module, but its not cheap.
    Best regards
    -David Evans
    Cadlink.
  • widget
    11 November 2004 at 12:48
    thanks for the reply
    signlab is a bit out of my price range at the moment,
    i was going to get signgo but it does not support print and cut for the pc600:(
    does anyone have roland colorchoice please 🙂
    thank you
  • Roy Roffey
    11 November 2004 at 20:09
    hi buddy
    all you have to do is call roland tech support (bloke called mark) and ask for a disc, they will supply one free of charge. I done it myself today
    best wishes
    roffs
  • widget
    11 November 2004 at 21:51
    Thanks for that will phone them tomorrow
    does anyone use this colorchoice?
    is it any good?
    is it signmaking software or is it just for doing small decals etc
    thanks
    12 November 2004 at 10:05
    widget
    if you are saying that the print & cut does not line up it is not the softwear but the pc600 wants adjusting
  • widget
    13 November 2004 at 11:20
    Can you point me in the right direction for setting up my pc600?
    its not far off just maybe a millimetre on 1 side of the cut and inwards a millimetre on the other side.
    hope you know what i am trying to say.
    also if i do a circle the cut does not line up 100%
    13 November 2004 at 12:04
    has your 600 just had a new head fitted ?
    the circle not closing may be just the knife facing the wrong way
    cut 2 circles if the second one is perfect then thats it else is the blade in good nick and is the ofset of the blade set for that type of blade .
    did you buy this second hand or from a dealer –
    sorry but the head print to cut adjustment is rather difficult to explane but can be better than a tenth of a mm
  • widget
    13 November 2004 at 13:20
    thnks but i think i have sorted it
    got the manual from roland and set up the print and cut alignment and all seems fine now
  • widget
    13 November 2004 at 13:40
    nope not sorted 🙁
    followed the instructions set it up printing and cuttin perfect in test.
    it then says to switch off to save settings.
    when i go back to test again its out of line again 🙁
    its doing my head in
  • Carrie Brown
    13 November 2004 at 20:43
    might be a silly thing to ask but just in case:
    When you say you are switching it off, are you doing this by using the power button on the front panel and not by the main switch on the side?
    Stephen 😀
  • widget
    13 November 2004 at 23:22
    i am switching it off by the power button on the front panel
