Home Forums Sign Making Discussions General Sign Topics what should i do print or sub-out 35 x 2.5 metre banner?
  • what should i do print or sub-out 35 x 2.5 metre banner?
    Posted by Pryam Carter on 15 February 2008 at 19:42
    I have a job to do shortly, its a 35 metre by 2.44 metre banner for a local housing development firm.
    The question is, do i sub it out or do i have a go myself?
    If i sub it out i can buy it hemmed and eyed and then just fit it on site, the banner will be printed at full width so no welding needed (unless the banner moves in print). By subbing it out i will not make as much money though.
    I have a soljet iii that can print at 1360mm so i would have to print 2 widths at 1220mm and then weld them together with my Lester machine straight down the middle. This way i can control quality of print and make more money but will the hem look bad and will it be strong enough?
    What would you do?
    Nick Walker replied 17 years, 10 months ago 9 Members · 19 Replies
  • 19 Replies
  • Lee Ballard
    15 February 2008 at 20:36
    If you’re confident of doing the join then I’d say do it in house and maximise profits.
    15 February 2008 at 21:16
    unless you have it properly heavy duty stitched or welded, sub it out.
    a good source banners this size is superwidegraphics.com and speak to "Guy". they offer very reasonable prices and the job is out your hair allowing you to get on with other orders. yeh you may make a bit more producing in house, but think of the print time, then the welding and hemming.
    if you hem it in house, there is also the possibility of it falling to bits in high wind. then your back to the drawing board.
    15 February 2008 at 21:50
    print it with a 2.5mtr wide machine.. sub it, too risky.
    Consider this:-
    1: Joining the banner, as rob said.
    2: The banner weight on the take-up can affect your length, so lets say you printed the first bit correctly, then the second bit actually with the 180degree setting set. They try and stitch you may find it will not line up side-by-side. The roll gets heavier and heavier and roll get lighter behind then machine therefore the feed rate changes.
    3: Power cuts, need i say more.
    4: You know that your PC, Rip and printer can print overnight without locking up. Likely will take that long.
    5: Full set of carts.
    6: Big enough table to cut it??
    7: Transporting the banner to the location to be installed, delivered to the location.
    8: Eyelets and stitch/tape plan
    9: Wind , Slits, Mesh
    10: fixing for the banner (how strong, remember solid banner will create a boat sail while needs serious fixing)
    15 February 2008 at 22:21
    11: Make sure the image is made correct
    12: You are likely to use % blow-ups, must get it right lol
    13: PDF actually has a 5mtr limit if your using that
    14: DPI drop when enlarging, becareful
  • Karl Williams
    15 February 2008 at 22:26
    Sod it Dave. I’ll sell me printer and sub it all out from now on. 😀
    15 February 2008 at 22:35
    sub it, never mind Daves list,
    you wont get the join to line up, end off
    15 February 2008 at 22:40
    quote Peter Normington:
    that thought did go through my mind…so how do the ‘bigger boys’ do it? 😀
    15 February 2008 at 22:42
    i would defo sub it… just im sorta fast typer and that start thinking of all the problems that should come up.
    Its tempting when you got that printer ready to go, then buy the materials and then screw up loosing your profit lol
    15 February 2008 at 22:46
    quote Nicola Rowlands:
    they print in one go nik… 5m wide printers, low resolution, very fast print options, fraction of ink actually used, very cheap bulk ink systems etc high frequency welders for hemming, automated eyeletting machines etc etc. 😕
    15 February 2008 at 22:52
    quote Robert Lambie:
    they print in one go nik… 5m wide printers etc 😕
    :doh: yeh but im in thinking mode and was wondering how they did the big ones, like for example: george square glasgow, building on the left of the witherspoons pub…i stood below and counted the seperate pieces..and thought….’how did they join that together perfectly vertically’ typical me, likes to know everything 😕
    15 February 2008 at 22:56
    you didn’t want to get up and feel it?
    15 February 2008 at 22:57
    quote Dave Rowland:
    dave if i had ladders…..i would have 🙄
  • Karl Williams
    What a big one with lots of joins? 😕
    15 February 2008 at 23:06
    quote Karl Williams:
    😀 😀 😀 :lol1:
  • Jason Xuereb
    15 February 2008 at 23:52
    We did a 5 metre banner.
    The line up on the take up roller was off. When the banner got weld by the end of the banner the text was off by about 2-3m. I could notice it. Wouldn’t want to see what happens with a 10+ metre banner if you haven’t got everything lined up perfectly.
    16 February 2008 at 00:06
    im sure if you look at the live glasgow webcams you will see what im on about 😀 not tonight though its too dark 😉
    http://www.glasgow.gov.uk/en/AboutGlasgow/WebCams/#
    16 February 2008 at 00:21
    great link nik… have to say for nearly midnight in Georges square it looks completely dead! 😕 traffic and bodies are buzzing at this time of night. 😕
  • Pryam Carter
    16 February 2008 at 09:14
    Sub it i shall!!
    I already spoke to the lads at superwide graphics, i’ve used them in the past and they have always done a good job.
    I do have a high frequency welder and have welded stuff together quite a lot but never anything that long.
    Fair point about the print not lining up too.
  • Nick Walker
    16 February 2008 at 12:15
    Hi Pyram
    Yes def sub it – its just not worth the hassle of doing yourself especially as you will have to make such a long welded hem. I also reckon I could buy that in cheaper than I could print and finish it anyway.
    Nik – I used to produce the George Square banner until my client went t1ts up! It was the first really big job I did – quite a task at 55m x 17.5m!
    Cheers. Nick.
