Home Forums Sign Making Discussions Vinyl What paint to use for Vinyl mask onto rough cast wall?
  • What paint to use for Vinyl mask onto rough cast wall?
    Posted by Martin Manley on 28 May 2018 at 13:07
    Hi everyone,
    Customer wants disclaimer notices painted onto his exterior walls (won’t have panels). I’ve painted rectangles and ordered vinyl masking film and now need advice on best paint to use. Wall is fairly rough cast and has a porous render – any help gratefully accepted… 😎
    Martin
    David Stevenson replied 7 years, 6 months ago 6 Members · 6 Replies
    28 May 2018 at 13:38
    hard one without seeing first hand, but on a rough wall, ide just use a masonry paint.
    if stencilling on, you are going to have an issue with the vinyl sticking properly if it is rough, your next problem is because it is rough, the paint will bleed inside/under the vinyl stencil.
    if this is the case, it maybe best using a "short hair" 100mm roller with very little paint on it and apply. building the paint density up in layers. any bits that are too rough, just dab them in with a brush.
    i would do the first one as a test though, and when done remove the stencil and see how it looks.
    between coats, you could also glaze over it with a heat gun to speed up coats drying time.
    on a side note, the customer isnt always right. :smiles:
    you need to make him aware of the issues that will arise from him not wanting a panel and the extra time this will take you. so make sure you charge him correct.
    28 May 2018 at 16:01
    Agree with Rob, we did some stencils on a lime washed wall, and it bled under the stencil. Dabbing the paint with a sponge worked for us.
    Unless it is perfectly smooth you’re likely to encounter problems.
  • Martin Manley
    29 May 2018 at 08:01
    Thanks guys,
    I was thinking more of a one coat gloss so I only had to do it once, but I’m seriously thinking of telling the customer it can’t be done on such a wall anyway…
  • David Gwyndaf Povah
    29 May 2018 at 09:24
    hi
    one shot enamel is good for painting stone ive used it in the past or Portland stone / sandstone etc never had a problem
  • Simon Worrall
    29 May 2018 at 12:00
    To prevent seepage under the mask, paint a first coat with a clear
    Then paint the colour you want on top of the clear.
    This will seal the mask against further ingress of paint, and any clear that gets under the mask will not really be very visible later.
    I would use a quality external acrylic paint for this job.
    Simon
  • David Stevenson
    29 May 2018 at 16:57
    Here’s one we done in our workshop recently. Used a heat gun to press it as tight to the wall as possible. Painted using emulsion with a brush. Quite fuzzy round the edges but as good as I’d say you’d get on that type of wall
