Activity Feed › Forums › Sign Making Discussions › General Sign Topics › what method can i use for branding televisions?
Posted by Gary Birch on December 21, 2007 at 2:47 pmHi folks
I have until now been branding some plasma screens using self adhesive vinyl for a customer. They now have a requirement for something a more permanent.What options do I have here??? Is Dye Sub something I can consider??
Please bear in mind that each logo is usually no bigger than 125 x 40mm
Any ideas appreciated.
Thanks in advance
Gary
Gary Birch replied 16 years, 4 months ago 4 Members · 15 Replies -
You can due sub onto anodised aluminium, that might be an idea, If not then Chris has the idea, doming.
Hmmm I hadn`t considered doming. How easy is this process and what is the drying/setting time??
Also what is the maximum size you would recomend.
Gary
doming is a simple process but like most things it does have its pit falls.
if you have a print and cut machine, its a good add onsetting time approx 8 hours the size you mentioned is about as big as i go, half that size more cost effective
Apologies for being dumb here Chris. I do have a print and cut machine.
The logo I have to do is a a logo and then text. How would you do this?
Is it a case of applying the vinyl and then doming or can you dome and then apply?? If the latter would you just have an outer shape which houses the detail and then dome on top of that??
As I stated earlier these are to go on plasma screens so need to look the best they can.
Gary
print a sticker as trick as you like cut to almost any shape. then apply the resin which will flow out to the shape.
let your imagination run riot.
Chris
Will this be more permanent than SAV tho?? Maybe I could get some hi-tack vinyl to print onto.I think I will buy in a doming kit and have a play.
Thanks for your help. Its much appreciated.
Gary
you print on to you standard print materials. and as its indoors should probably outlast the screens.
Ok thanks for that info.
I have ordered a starter kit and will give it a blast.
I will let you know how I get on.
Thanks again
Gary
Thanks very much Chris.
I hope I can return the favour one day.
Gary
Well the starter doming kit arrived today and thanks to the help here I think the initial results were pretty good, apart from a few over fills that is lol.
It has given me ideas now for other uses, corporate gifts being one of them. Can anyone give me some contact details for companies who supply the blanks eg key rings, cuff links etc.
Thanks in advance
Gary
Give Mastergrave a call, some of their stuff might take doming resin, but its mainly aimed at diamond/laser engraving.
If nothing else, may give you a few ideas
Thanks guys I will look into it on Monday. I did actually buy the kit from makeagift and have tom agree with you Chris that they were a pleasure to deal with.
Thanks again for your help
Gary
