Home Forums Printing Discussions Uniform Printers what is the standared material width for grenadier?
  • what is the standared material width for grenadier?
    Posted by Russell Huffer on 4 July 2008 at 18:58
    I have never used such narrow material in my Grenadier, however I have two banners to print one 12 m and the other 18 m would normally print side by side as only 600 wide but in this case would mean wasting 6 m of material and customer in no rush so bought a roll of 750 wide banner.
    3 Head crashes later works out that the when loaded normally the left edge (view from front) is only just under a roller and within a meter or two the rollers push the edge of material out causing the whole edge to lift and head hits it, I solved problem by taking off rear flange and putting a roll of insulation tape on spindle first moving roll over by about 10 m/m, only problem now is this profile has a confidence strip and 4 of the colours are missing the edge of vinyl causing a build up on printer bed.
    My question is is this a problem with Roland design or is 750 not a standard width ? as this has caused my a lot of delay and mess.
    Russell.
    Mike Grant replied 17 years, 6 months ago 3 Members · 3 Replies
  • Kevin Flowers
    4 July 2008 at 19:48
    Russell
    i run 760mm on my Soljet no problems, if i remember correctly i move the first pinch roller (one nearest head) across away from the edge so that the roll fits nicely between that pinch roller & the one on the opposite side of the roll, i don’t use the intermediate rollers on the narrow rolls.
  • Russell Huffer
    5 July 2008 at 17:32
    Thanks for reply Kevin, I was unaware that the first pinch roller moved, I will look Monday when in the office, you run 760 if my material had been 760 there would not have been any problems as there would have been 11m/m under pinch roller not 1m/m. This is why I question the 750 size as being non standared, my normal banner materials I use are about 1.2 and 1.8 wide and never had problem with pinch roller lining up on these sizes.
    Russell.
  • Mike Grant
    5 July 2008 at 19:59
    Depending on which supplier you use it comes in 750 or 760mm
    If you use Hexis you get 760 or Metamark you get 750mm (or maybe the other way round 😳 )
