Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters what is the difference between the following sensors please?
  • what is the difference between the following sensors please?
    Posted by Andrew McCreadie on 12 August 2005 at 22:46
    Could someone please tell me the difference between the Optical Sensor and the Auto Registration Mark Sensor on the Graphtec CE3000/60 cutter.
    Many Thanks
    Andy
    Andrew McCreadie replied 20 years, 4 months ago 4 Members · 6 Replies
  • Marekdlux
    13 August 2005 at 00:46
    If you don’t have a digital printer you don’t have to worry about either.
    The optical sensor is one were you have to manually line it up over your registration marks, the other one does it automatically. ( I think )
    -Marek
  • Jayne Marsh
    13 August 2005 at 09:39
    Ill ask Jeff ( Graphtec service manager ) when he gets in, hes just fitting a small job for me this morning in the rain, he will be soooo pleased, he hates the rain :lol1:
  • Andrew McCreadie
    13 August 2005 at 12:17
    hi Marek & Jem
    Thanks for your replies, I was just wondering what the difference was as I will be feeding printed media through it from a normal inkjet.
    Just wondering if I need registration or if optical would suffice.
    Many Thanks
    Andy
  • jeffus – Graphtec
    13 August 2005 at 12:19
    Hi ,
    The Ce3000-60 Mk2 comes with registration mark sensor as standard, the names for this sensor varies from make to make “optical , ARM ,OPUS etc,
    there is a manual method that can be done, using a loupe or a pen,
    the Ce3000 has an Ilustrator plugin for mac and pc (CS2 end of August)
    , and a windows driver,
    and I think very soon they will be having a corel draw plugin,
    the FC7000 series all now have the regi sensors as standard also.
    They use 2, 3 or 4 regi marks on the printed job and the FC7000 can use
    extra marks on long jobs for greater accuracy.
    sorry to go on
    Jeff
  • jeffus – Graphtec
    13 August 2005 at 12:21
    Hi again you posted before i rambled on ,
    for contour cutting your prints the standard CE3000-60 Mk2 with arm will do the job, no problem.
    Jeff
  • Andrew McCreadie
    13 August 2005 at 14:17
    Cheers Jeffus
    Excellent info, thanks very much
    Andy
