Home Forums Sign Making Discussions Vehicle Wrapping what is the best wrapping vinyl on the market?
  • what is the best wrapping vinyl on the market?
    Posted by radecal on 12 September 2007 at 16:41
    Hi everyone, whats the best digital vinyl for wrapping vehicle, we have been using oracle 3951 series with the clear 3951 as an over laminate, but it keeps coming away from deep joints. Any suggestions would be great. Also whats the best size vinyls to try and fit we have both a versacamm 300 and a 540.
    regards
    Greg
    mod-edit
    This post has now been moved.
    Please use the correct forum when posting, as future posts maybe deleted.
    radecal replied 18 years, 3 months ago 5 Members · 7 Replies
  • 7 Replies
  • Josh Steenbergen
    12 September 2007 at 18:43
    I had that problem too…but I was using 3m vehicle wrap material…I ask a friend that has been in the bis for awhile and he told me to use this product from 3m called tape primer…I works real well..try that and see if that helps you out..and you can still use oracals product if you still like it better than the rest of the products…
    josh
    12 September 2007 at 19:12
    How do you apply your wrap vinyl, wet or dry?
    what areas of the vehicle, and make of vehicle is it failing on?
    how do you prep the surface of your vehicle before application?
    once your wrap has been applied what procedure do you use to heat/cure the vinyl?
  • radecal
    13 September 2007 at 09:01
    We apply the graphics dry after we clean the surface with isapropenol cleaning fluid. It is failing on the recesses. We use a heat gun to apply the vinyls into the recesses.
    Thanks for all your help people.
    13 September 2007 at 09:29
    Once you have finished fitting do you go back and re-heat the recessed areas to the correct temperature?
    Each wrap vinyl will have a temperature that the vinyl should be heated to which ensures that it loses all it’s memory and ensures the adhesive has cured. This should be done using something like a digital thermometer to ensure you have heated to correct temperature.
  • radecal
    13 September 2007 at 09:54
    Thanks Martin. Could you tell me where I can get my hands on one of these thermometers? I heard that the vinyl has to be heated to a certain temperature but we have been doing it by trial and error. This would explain why some parts of our wraps are perfect whilst others are coming away. Great result for the Jocks last night!
  • Derek Heron
    13 September 2007 at 11:09
    hi over there is that the guys in washington
    this was posted recently http://www.uksignboards.com/viewtopic.p … art#232792
    although you should check with your vinyl supplier first to see what the spec needed for your application
    Derek
  • radecal
    13 September 2007 at 12:02
    Thanks Derek,
    yes its the lads from Washington. We’ve just ordered this thermometer.
    Thanks again
