Home Forums Sign Making Discussions Vinyl what is the best way to remove old vinyl?
  • what is the best way to remove old vinyl?
    Posted by Kevin Fryer on 15 May 2007 at 12:43
    HI WHAT IS THE BEST WAY TO REMOVE OLD VINYL.
    IS THERE A SPRAY?
    HOPE YOU CAN HELP ?
    THANKS FOR LOOKING KEVIN
    Phill Fenton replied 18 years, 6 months ago 18 Members · 40 Replies
  • 40 Replies
    15 May 2007 at 13:20
    Depends on what type of vinyl you are trying to remove, heat works quite well and so does a steam wallpaper stripper, you can buy plastic tools from people like Jag Sign Supplies that aid you in starting to lift the edge of the vinyl if you have no finger nails (like me :lol1: ) or you are worried you will chip your nail polish!!!
    There are a couple of chemicals on the market to aid vinyl removal, 3m do a spray to halp remove vinyl and one to help remove glue as well but they are expensive as most 3m products are. I believe Grafityp also do one and there is a link to their website on the homepage.
  • Peter Mindham
    15 May 2007 at 20:26
    Hi Kevin
    Stop SHOUTING your giving me a headache!! 😀 😀
    15 May 2007 at 20:36
    quote KEVIN FRYER:
    IS THERE A SPRAY?
    HOPE YOU CAN HELP ?
    Get someone else to do it!
    No only joking, if i have originally fitted the vinyl I am happy to remove it, but at a cost, I wll give the customer an estimate in terms of time @ an hourly rate, but most opt to get a lad to do it a far cheaper rates.
    Like has been said warm air or steamer works well, but unless the vynil is really old and brittle, the chemicals are more hinderance than help.
    You can use nitromores it works well … NO DONT! good stuff for stubborn vinyl on GLASS though
  • Steve Underhill
    15 May 2007 at 20:40
    I use a hot air gun on a low setting, and to get old adhesive off a bottle of "right off" £8 from dorotape, citrus based spray leave it on 2 minutes and the vinyl just wipes off with no effort.
    for older brittle vinyl on vans I use a chainsaw and then metal filler.
    15 May 2007 at 20:45
    Steve you’d have no problems with residue glue with your last method 😀
  • Steve Underhill
    15 May 2007 at 20:52
    No I just cut the whole panel out, tape a bit of cardboard in there and a bit of metal filler on the edges, to make it look good.
  • Kevin Fryer
    15 May 2007 at 21:23
    great thanks every body.got a few ideas to try out.
    think i leave the one about the chain saw lol
    15 May 2007 at 21:28
    Kevin at this time of the year your best method is just peeling it off, if you use heat you are more likely to leave glue behind, same with the melt sort of products, glue is almost as bad as vinyl to get rid of, you can use glue and tar remover, then depending who it is for give it a "T" cut won’t get rid of all the ghosting but will look better.
  • derek longhaven
    15 May 2007 at 21:29
    quote KEVIN FRYER:
    IS THERE A SPRAY?
    HOPE YOU CAN HELP ?
    Depends what you are removing it from and whatever the tools recommended here you’ll find the hairdryer is not only the cheapest but the best.
    15 May 2007 at 21:33
    quote derek longhaven:
    quote KEVIN FRYER:
    IS THERE A SPRAY?
    HOPE YOU CAN HELP ?
    Hair dryers are for drying hair, buy yourself a professional, adjustable hot air gun, about 25 quid will get you a dewalt, including several nozzles.
  • derek longhaven
    15 May 2007 at 21:35
    quote Peter Normington:
    quote KEVIN FRYER:
    IS THERE A SPRAY?
    HOPE YOU CAN HELP ?
    Well only an idiot would waste £25 when a £3.50 hairdyer does the same job. There again evidently you don’t own a hairdryer
  • Steve Underhill
    15 May 2007 at 21:36
    have to agree with Peter there, got the de walt one for £30 its brilliant.
    and also a hair dryer isnt going to wrap a van if you ever want to go that route.
    15 May 2007 at 21:37
    sorry Derek have to disagree you can get excellent heat guns quite cheaply with variable temperatures, these of course can be used in vinyl application as well, so an investment at the end of the day. ad by the way where can you buy a hair drier for £3.50 🙄
  • derek longhaven
    quote Steve Underhill:
    Its to remove vinyl not wrap a van.
    Most can’t apply/remove vinyl, let alone wrap a van?
  • derek longhaven
    15 May 2007 at 21:40
    quote Lynn:
    Both the normingtons disagree with everything I say, I don’t care, because you’re wrong.
  • Steve Underhill
    may as well have the right tool for the job was all I was saying.
    but I can assure you a hairdryer isn’t the "best" maybe cheapest tho Ill give you that.
    15 May 2007 at 21:44
    quote KEVIN FRYER:
    IS THERE A SPRAY?
    HOPE YOU CAN HELP ?
    Only an idiot would waste £3.50 when you could just wait for a warm day 😀
  • derek longhaven
    but I can assure you a hairdryer isn’t the “best” maybe cheapest tho Ill give you that.
    Same argument with using Coreldraw and not using Flexisign / signlab etc then?
  • Steve Underhill
    15 May 2007 at 21:48
    Im not arguing,
    arguing on the internet is as pointless as booing at the special Olympics.
  • derek longhaven
    15 May 2007 at 21:55
    Im not arguing,
    No the right tools for the job comment, the argument is exactly the same, why buy a heat-gun when your hairdryer will achieve exactly the same result, why buy signlab or flexi when corel will ‘get you by’ ?
    It’s the way you perceive your end result and the easiest way to achieve your aim. Hell i’ve seen fantastic results with something as accessible as paint and a brush for gods sake!
    15 May 2007 at 21:58
    i take it every body has had a bad day then 😉
    i love my corel, heat gun and steamer.
  • Steve Underhill
    15 May 2007 at 21:59
    I do use corel draw,
    Signlab or flexi just make it quicker easier and less infuriating for sign work sometimes I guess, but I also do a lot of vector drawing, so Im fine with it.
    point taken on the hairdryer, whatever works for you.
    No bad day here Chris, just hard to express a tone of voice on a forum, Im always happy.
  • Andrew Boyle
    15 May 2007 at 22:06
    Hey Derek…………you’re a funny guy 😀
    15 May 2007 at 22:11
    derek please read the board rules 😉
  • Adam Triggs
    I Agree with Chris,
    Derek, take a chill pill you seem a little hot under the collar, turn that hair dryer down a bit.
    So In Summary……
    Heat guns and Hair dryers.
    Chemicals but test a small area first.
    Steamers 🙂 (i think every agrees on that note)
    Ahhhh, Now we’ve got that covered…..
    And I’m the one who’s been to the pub and drank Stella all night 🙂
    Adam
  • Andy Gorman
    15 May 2007 at 22:18
    I use a hairdryer. It is probably a bit slower than a heat gun, but the first time I picked up a heat gun by the metal nozzle I left a fair bit of skin on it and decided I didn’t like it. Also, there is no chance of causing any damage to paintwork with a hairdryer. The trick is to warm the panel up, not just the vinyl.
    15 May 2007 at 22:36
    quote :
    the best bit of advice all night thats why i like my steamer.
    15 May 2007 at 22:46
    A useful tip I have discovered after years of experimentation..
    To minimise glue left behind on the panel – try to get the panel hotter than the vinyl (though the vinyl also needs to be heated to stop it being brittle) but if you can get the panel hot the glue will release from the panel and come off with the vinyl (rather than be left behind after the viny is pulled off). As Lynn said earlier – you can spend more time removing the glue than the vinyl – so if you can get a "clean" panel when you remove the vinyl you will save time.
    I’ve always found a walllpaper stripper to be best – this ensures the panel as well as the vinyl gets nice and hot and minimises glue residue.
    I should know – I have spent a lifetime in research and development to produce a quick and easy method of removing vinyls. Once my "top secret" invention is perfected and brought to the market – I reckon I will retire a millionaire 😎
  • Steve Sandy
    16 May 2007 at 08:00
    Hey Andy,
    The way your holding that pint glass looks like your trying to cool your fingertips down, Always a good excuse for a pint. 😀
    16 May 2007 at 11:31
    quote KEVIN FRYER:
    IS THERE A SPRAY?
    HOPE YOU CAN HELP ?
    sorry, but that is simply wrong! 🙄
  • Gavin MacMillan
    16 May 2007 at 13:00
    I’m annoyed I’ve been busy today and missed all this! For what it’s worth, I use a hair dryer, not cause it’s best but because there is no risk of damage to anything or burning myself. I have a heat gun and use it when it is needed. As said before the steamer is the way forward (tools for the job – steamer for removing wallpaper? no, it’s good at vinyl too)
    quote :
    Im not arguing,
    brilliant… I’m using that one!
    Just to drag out my post and cause I’m on my lunch and feeling pretty good today, as not everyone is it seems, I’ll blether on for a sec. I post on another forum (not sign related) and there is loads of bitching and sniping on it. Most of the time it’s because people misread others posts, but at the same time if the original poster took more time to check that they didn’t come across as rude and bitchy it could all be avoided. To be honest I’d stop using the other one but it’s the best on it’s topic and fortunately UKSB is nothing like that so this was all quite pointless!
    Sorry if you just wasted your time reading that!
    G
    16 May 2007 at 13:28
    Just wanted to add to this thread before i edit it later tonight…
    Mr derek longhaven does NOT exist! this is a bogus account created by a certain company by the name of outline signs and graphics, yet again!
    apologies for the inconvenience caused by this… but i was merely giving them enough rope to hang them self. 😀
    should this person persist to cause problems on uksb i will submit their "full details" to the legitimate manchester sign company that they have given details of and claim to be from in this recent show of childish behavior.
    16 May 2007 at 14:11
    🙄 ………………. again (!)
  • Andy Gorman
    16 May 2007 at 14:29
    Well I never, what a surprise. 🙄
  • Andy Gorman
    16 May 2007 at 14:30
    Oh, I just wanted to get the 200000th article.
    There, that’s it. 🙂
    16 May 2007 at 14:31
    quote Andy Gorman:
    There, that’s it. 🙂
    :lol1: :lol1: :lol1: :lol1: :lol1:
  • Gordon Forbes
    16 May 2007 at 21:48
    I just did 2 large removal jobbies of vinyl. The scrapers from JAG can recommend them very good for getting a start. Didn’t use any heat at all just peeled it slowly. Had some glue residue on the colder bits where it snapped away Meths took care of that.
    The biggest problem was getting the traffic film off the dibond.
    A weak solution of bleach did the best and a good clean after to remove residue.
    Always somebody spits the dummy out cause they think their opinion is the best.
    By the way Derek what type of car do you drive? Old LADA perhaps?
    Goop
    OOOppppsss never read all the threads above
    16 May 2007 at 22:53
    I’ve got a question 😮
    I find my hairdryer is over the top when drying my hair in the morning. I was thinking of buying a hot air gun instead – something that can give me a range of "little or no heat" to "burn your brains out yabast!!".
    My Rowenta hairdryer only has two settings ("hot" and "Ooyabast") so I was hoping for a hot air gun with a much greater range of heat settings with much finer incremental settings than the old Rowenta.
    Any suggestions 😮
  • Andy Gorman
    16 May 2007 at 23:00
    Phill, put yer ‘ead in the oven. Mine has 9 heat settings, and a grill.
    16 May 2007 at 23:07
    I tried that Andy… but the gas won’t stay on if the pilot light hasn’t ignited the gas and allowed thermal expansion of the copper tubing to permit a free flow of gas into the oven chamber.
    When I tried a simple noose around my neck the rope broke when I kicked away the stool 😕
