Activity Feed › Forums › Printing Discussions › Printer Ink › what is the best t-shirt material using Eco Max inks?
Posted by Martin Oxenham on November 2, 2008 at 10:33 pmWhich is the best material for this using Eco Max inks that won’t scratch.
peely replied 15 years, 5 months ago 7 Members · 11 Replies -
Hi Martin
We have used both Graphy and Victory both have been ok no complaints.
Neil
Used both those myself
Best to leave them at least 24 hours before pressing…. seems to make a slight difference in the resistance of the print
i have used Chemica Easyprint for 2.5 years. 10-20% of prints are used 1-2h after printing if i’m in hurry, usually everything works out like it should be, if the colours are very dark, final result can sometimes be a bit lighter when used too soon.
easyprint is 160mic and 130-150c / 15-20sec. -
No. No no no. The shirt must be turned inside out.
You can just imagine what happens when you stick 150-200c iron to vinyl 😀 -
quote Riku Suominen:No. No no no. The shirt must be turned inside out.
You can just imagine what happens when you stick 150-200c iron to vinyl 😀Well this is what concerned me ! 😕
We have used T-shirt vinyl from Xpres, with great results, which can be ironed over no problem.
We are now looking for a more elaborate design for the shirts.
We where demonstrated a Versacamm which gave impressive print results onto the vinyl, although when applied to the shirt, the design could still be felt as though it was a sticker attatched to the shirt.
We where told that there was a matt vinyl which would probably give a better feel ?
But neither could be ironed over, which we felt, after speaking to several customers would be a disadvantage ?Our only other option is a DTG printer, but we are just trying to talk ourselves round to £8 – 10k ??!! 😮
quote :the design could still be felt as though it was a sticker attatched to the shirt.
i have tried all if not most and thats the level of it no better than sticking a sticker on, it does have limited uses and the clear mat is the better but a poor second place to other methods imo.
so i am giving dye sub a go
quote Chris Wool:quote :the design could still be felt as though it was a sticker attatched to the shirt.
We too looked at Sub, but was told that for mouse mats, mugs, etc it was good, but for shirts, wasn’t the best, and also being tied to the Poly mix material, decided to try and find another route ?
But, ……………………..which one other than DTG ???
DTG is supposed to be a nightmare with printers clogging up if not used all the time as far as I can make out and many don’t deliver what they promise. Have a look at the DTG printing forums and you will see what I mean a lot of unhappy peeps by the look of it
quote Gordon Forbes:DTG is supposed to be a nightmare with printers clogging up if not used all the time as far as I can make out and many don’t deliver what they promise. Have a look at the DTG printing forums and you will see what I mean a lot of unhappy peeps by the look of it
Yeah, I have been reading a lot on t-shirtforums and must admit a lot seem to be unhappy, especially if they are not being used regularly, and especially with the white ink.
The only one that seems to get a good report is the Brother one, which doesn’t print white, unless you go for the new model.
But at over £12k you’d expect it to work faultless.
Maybe Roland should bring one out and show them all how its done ! 😀
