Home Forums Software Discussions Signlab Software What is best route to export text & logos from 6e to Cor
  • What is best route to export text & logos from 6e to Cor
    Posted by Maureen Ellis on 8 July 2004 at 15:41
    What is the best route to export text & logos from 6e to Corel 11,
    similarly is there a preferred method to import 3rd party artworks
    into 6e ?
    E-Man replied 21 years, 4 months ago 3 Members · 3 Replies
  • Brian Hays
    8 July 2004 at 15:44
    Use the EPS filter in Signlab, we do it all the time.
    Just make sure when you are in Corel you use the EPS, PRN, EPS Postcript Interpreted filter, otherwise you will just get a grey box in Corel.
    Use EPS in Corel as well if you want to take files the other way…
  • Frank Droog
    8 July 2004 at 20:31
    If just doing basic stuff, eps export should be fine or Ai export.
    But if you have gradient fills in Signlab i would recommend that you install the Apple Color Laser Writer printer into Windows via Add Printer from Control Panel. Then, set the Port location of the Printer driver to File.
    Then from Signlab, instead of Exporting, go File/Print and print to the Apple Color Laser Writer printer and when prompted for a File name, give it an EPS extension.
    Transferring gradients from one program to another is a struggle but the Apple color laser printer driver seems like a good universal translter.
    And as Brian said, use “eps interpreted” in Corel to import
    frank at cadlink
  • E-Man
    9 July 2004 at 13:25
    sounds too simple but………….
    sometimes cut and paste works…
    all depending on the artwork, but for ease of use its worth trying first.
    but as already said, eps works ok if this fails…
