Home Forums Sign Making Discussions General Sign Topics what can i use to clean a laminator with?
  • what can i use to clean a laminator with?
    Posted by Hugh Potter on 28 May 2013 at 15:59
    Hi all,
    just picked up an easymount 720, had very little use by the looks of it but has been stored for a while, there’s a bit of muck / a few gluey marks on the rubber rollers, whats the best thing to clean this with??
    also, I notices the feed roller bars are a little scabby, the chrome is going, and one bar has a slight wobble to it (bent), I can wrap the bars to protect the film but am uncertain of the bar will affect anything due to an inconsistent pressure right across the vinyl.
    while I’m at it, can anyone recommend a good matt / gloss lam please? it’s mostly for posters / photo prints.
    thanks,
    Hugh
    Kev Mayger replied 12 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Kev Mayger
    29 May 2013 at 11:00
    Hi Hugh
    You will be able to get a roller rubber block from most laminate suppliers. You basically rub the block on the rollers across the dried glue residue. After this I cover the rollers in mount film with the backing still on, let them spin a few times against each other then remove it taking all the sh1te with it. This is a generally good practice to do every couple of weeks to get rid of dust etc.
    29 May 2013 at 11:43
    thanks Kev,
    much appreciated.
    Hugh
    29 May 2013 at 15:13
    really do regular suppliers have this treatment to buy?
  • Kev Mayger
    30 May 2013 at 08:19
    Dave, I wouldn’t really call it a treatment it’s just a certain type of rubber that takes the dried glue residue off with a bit of elbow grease! If you speak with your laminate suppliers i’m sure they will be able to help.
  • Kev Mayger
    30 May 2013 at 08:22
    Like these…
    http://www.usi-laminate.com/store/wpbec … roduct=311
  • George Elsmore
    30 May 2013 at 09:45
    where can you get these in the uk lads?
  • Kev Mayger
    30 May 2013 at 10:08
    Got mine from Atech
