Home Forums Sign Making Discussions Neon, LED, Lighting What board is best for shopping centre sign?
  • What board is best for shopping centre sign?
    Posted by Tim Painter on 15 October 2003 at 08:35
    Can anyone advise me on a suitable board for use in a shopping centre.
    The signs are for a Flower stall which is being made from mainly steel to keep the fire officer happy.
    The panel sizes for the signs are approx 1m square.
    I could fit direct to the stall but the customer would rather i did not so they can change the stall re paint etc more easily if they have to.
    Cost is a consideration.
    I assume fomex is out?
    What materials without high costs are likely to keep the fire officer happy?
    Im a newbie so would appreciate and advice how ever small. 🙂
    Robert Lambie replied 22 years, 2 months ago 5 Members · 6 Replies
  • Tim Painter
    15 October 2003 at 10:20
    Bump Sorry….. 😥
    I need to get moving on this one so HELP very much appreciated 😆
  • Mike Brown
    15 October 2003 at 11:50
    Hi Tim,
    From memory, Foamalux (from Brett Martin) is Class 1 fire rated?…
    check out: http://www.brettmartin.com/semifinished/foamalux/fire.shtml
    …I would go for 10mm or so thickness.
    Alternatively, you could contact Ashby and get an aluminium plate supplied with/without rounded corners, grey to the rear and coloured to the face using vinyl (they apply this if you wish) and deliver it pronto!
    don’t have the number to hand – but use the search box above to find other posts about them…
    good luck
    more soon
    mikethesign
  • Tim Painter
    15 October 2003 at 12:39
    Got your phone message Mike many thanks.
    The site is obviously a very useful resource thanks for the link.
  • Graham.Scanlan
    15 October 2003 at 13:42
    most foam pvc’s are class 1 fire rated now, and if you are thinking of going down the 10mm route then consider alucolor etc
    it would be a far more stable sign material
    i know that forex comes with a class 1 fire rating & 5 year warranty (white only)
    and foamalux comes with class 1 fire rating
  • Innocent
    15 October 2003 at 23:12
    dibond or similar is another option, not as thick as foamex but just as strong and a 2mm thick sheet is around the same price as 5mm foamex.
    16 October 2003 at 00:31
    alucolour, rynabond or dibond…. best alrounder i would say. light, strong, nice finish, easy cut/filed, doesnt soil easy etc etc etc
    foamex is fine for something like this indoors but does hold dirt when its being wiped down witha wet cloth, unless the type with a gloss face. foamalux etc
    if these signs are low, like along the front of a stall i would use a clear vinyl over the face. this stops the fingers picking off the letters when buying or looking at stuff… 😉
