Home Forums Printing Discussions Roland Printers Waterslide decals on PC600 ?
  • Waterslide decals on PC600 ?
    Posted by Mike Fear on 8 October 2004 at 16:22
    Has anyone tried or had any luck printing waterslides on a PC600 or PC60 ? I’ve used Alps and Prinitva thermal printers before for making them ( on laser waterslide paper ) and know the Roland is based on these.
    I have tried on a couple of brands of paper, but the ink ( especially the gold ) seemed to not adhere well to the paper and came out very patchy – printing in CMYK wasnt so bad, but still left areas of the print missing.
    I was using the normal ( resin ? ) ribbons, should I try with the wax ones instead ?
    Any help would be appreciated.
    Mike
    Chris Wool replied 21 years, 2 months ago 2 Members · 4 Replies
    8 October 2004 at 17:06
    hi
    if you were ok with the alps in the alps printer then use those carts the pc60 knows that it is a wax and carries on
  • Mike Fear
    8 October 2004 at 20:39
    Sorry to be dense here – do you mean put the Alps ribbons straight into the Roland and print as if they were Roland ones ? do I need to change the barcode stickers on them or just leave them as they are ?
    Mike
  • Mike Fear
    8 October 2004 at 20:40
    Should explain as well – the Alps printer I was using, the head is on the way out, so I want to use the Roland instead, rather than by another Alps one ( as they dont make them any more, so all you can get are second hand which tend not to last very long ).
    9 October 2004 at 08:26
    yep alps and printiva wax carts long time since i used them though part of the code tells the pc60 its wax else it will just cut the ribbon in half
