Home Forums Printing Discussions Roland Printers Water to solvent head conversion – advice please?
  • Water to solvent head conversion – advice please?
    Posted by Mark A Brown on 26 October 2015 at 16:31
    Hi Guys,
    Its cheaper to buy a water based DX4 print head and replace the manifold for a solvent one. Has anyone ever did this I’ve replaced many a manifold on heads now due to nipples snapping while damper changing.
    Is there any difference in solvent head from a water head other the the manifold?
    Hope some one can shed some light as I need to replace a few heads.
    From Mark A Brown
    Stafford Cox replied 10 years, 2 months ago 4 Members · 5 Replies
  • Mark A Brown
    26 October 2015 at 16:39
    http://www.printheadoriginal.com/en/pri … 04372.html
    is the cheap or what?
  • Kevin Flowers
    26 October 2015 at 18:40
    you might be better off going to digiprint used them on several occasions without any problems use to give a discount to board members ad on homepage
    http://www.digiprint-supplies.com/epson … lvent.html
  • Mark A Brown
    27 October 2015 at 09:46
    Hi Kev.
    I’ve used digiprint for ages now. But I’ve found a place thats meant to be selling dx4 heads for £270 against £411 from digiprint. Thought it might be worth trying one of their heads.
    27 October 2015 at 11:01
    Probably not Genuine Epson heads if they are that much cheaper, could be wrong but sure I read somewhere that Epson control the pricing of their heads.
  • Stafford Cox
    27 October 2015 at 12:03
    It is definitely possible to convert them but I find they never work quite as well once the manifold and gasket have been removed. Personally, I would just swallow the ludicrously cheap price Digiprint sell the print heads for and be done with it. After all, look at how quickly you’ll make the £500 back once it’s running properly.
    Stafford
