Home Forums Printing Discussions Mimaki Printers WASATCH SOFT RIP 6.4 CONTOUR CUTTING PATH MOVES
  • WASATCH SOFT RIP 6.4 CONTOUR CUTTING PATH MOVES
    Posted by kgraphics on 26 January 2009 at 15:02
    Hi all,
    First of all we have a Mutoh Valuejet 614, and we use wasatch softrip 6.4 to run that and our graphtec cutter, the problem i have is when im trying to print and cut, every illustrator cs3 file i load onto wasatch moves the cutpath by a few mm so it doesnt cut in the correct place. i have created the cutpath as a 0.25pt line and called it CutPath and have tried various things to resolve this but i am well and truly stuck now, has anyone else had this problem??
    any help would be greatly appriciated
    regards
    justin
    Andre Woodcock replied 16 years, 11 months ago 4 Members · 5 Replies
  • Andre Woodcock
    26 January 2009 at 15:27
    Justin, I had the same problem too. In Illustrator draw a box around the image you want to print & cut and try again.
    Good Luck
    http://wasatch.com/flash/english/cuttin … shWeb.html
  • kgraphics
    26 January 2009 at 16:10
    hi thankyou for your reply, ive just tried placing a box around it and also a cutpath box around it still no joy when i open it on the rip i can still see that it is out
    26 January 2009 at 18:32
    some times that rip shows the marching ants a little off, down to screen res i was told.
    are you sure that the graphtec cutting head is calibrated to the reg marks sensor ?
  • Russell Huffer
    26 January 2009 at 22:13
    Only time I ever had an alignment problem with my Graphtec using Wasatch is when I had selected centre on media, apparently this is a known fault on Wasatch.
    Russell.
  • Andre Woodcock
    28 January 2009 at 14:35
    Justin, remove the cutpath around the the box. click on this link below to watch the video
