Home Forums Sign Making Discussions General Sign Topics Warren Beard has a Screwing problem, help needed?
  • Warren Beard has a Screwing problem, help needed?
    Posted by Warren Beard on 13 July 2012 at 08:33
    right now that I have your attention! :lol1:
    In my haste to order a job for flat cut lettering I received them but they have the smallest of smallest locators on them and the screws are tiny. My problem is they are to be fixed directly to a wall so can’t use plugs due to size of screws.
    Anybody have any ideas of a way to fix these or do I cut my loses and order a new set with rods or something or am I missing the obvious?
    Warren
    mod-edit
    Please use descriptive topic titles!
    :rules:
    :lol1: :lol1: :lol1: :lol1: :lol1: :lol1:
    David Rowland replied 13 years, 5 months ago 5 Members · 5 Replies
  • George Elsmore
    13 July 2012 at 08:43
    Warren this might sound outlandish but I used tacks to fit the cups to the wall I driiled small holes pushed the tacks through the cups and filled the small holes with gripfill the lettering is still in place 2 years later i pass the job every day on the way to work 😕
  • Kevin Flowers
    13 July 2012 at 08:53
    Warren
    you could get yourself some dowel (6mm) drill the wall as normal but use a depth stop on the drill cut the dowel to same length. Punch dowel in to hole with a little adhesive then screw in as normal. you can even touch dowels in with a bit of paint to match the wall if need be.
  • Warren Beard
    13 July 2012 at 08:59
    great ideas thanks guys, will give it a go.
    Warren
  • Colin Crabb
    13 July 2012 at 20:40
    Used resin-fixing before with small screws before:
    http://www.screwfix.com/c/screws-nails- … /cat840022
    Pretty strong stuff once set
    13 July 2012 at 22:23
    You know Robert’s going to be complaining that you didn’t put this in Quote & Sub-contracting work section
