wall fixings for banner poles ?
Hey All, next week i’m installing some banners about 20ft up a wall, protruding at 90 degs from the wall, usnig the banner box banner tensioning system,
i was asked by the architect to use chemical fixed bolts, but i’m a little worried about the depth of the wall, i’m told i need to go about 120mm into the wall, with 30mm of stud sticking out,
what i’m worried about is drilling through the other side of the brick (assuming it is brick under the render), as obviously then the chem fix goo will be useless as it falls thru the back of the brick !
i do have some of these bolts that wind direct into the wall, drill a 10mm hole and wind them in (13mm thread) and tighten to 50nm, 50 nm is equal to about 37ft lb of torque, which certainly in mechanical terms, aint alot,
reason i wanted to try these is incase i go thru the back of the brick, they are not affected, or, when i drill the first test hole, and discover that i havent drilled right thru, then i can oversize the hole and use the chem fix as originally planned, my concern however, is whether or not the solid ‘screwed in’ bolts will stay solid and screwed in with constant pressures of wind blowing against the banners,
does anyone have any experience with the wind in bolt fixings ? or, if i do drill thur, is there any way of using some kind of insert to retain the chem fix at the rear,
any ideas before monday ?
i’m not allowed to use the normal style of expanding rawl bolts as the architect is worried they may damage the brickwork ?!
thanks in advance. Hugh
