Home Forums Vinyl Cutter Discussions Roland Cutters VP540 print head gets worse after cleaning
  • VP540 print head gets worse after cleaning
    Posted by John Dorling on 19 March 2010 at 09:14
    Hi All
    But of a muddle today, got some printing to do but half of the magenta head isn’t firing on all cylinders. Have done 3 cleaning cycles, normal, medium and powerful but now it seems worse! Any ideas what this could be? Physically the head looks ok and I have recently cleaned the wipers.
    John Dorling replied 15 years, 9 months ago 3 Members · 5 Replies
    19 March 2010 at 09:31
    some things to check
    is there actually ink in the cart.
    pump failed or leak on pipe
    capping station not sealed to head when cleaning
  • John Dorling
    19 March 2010 at 10:24
    OK Chris I’ll take a look at the cartridge. I have had a look at the capping station and all seems ok, and one side of the head is fine. What is the best way to check for leaks/blockages in pipes? I have had the VersaCamm apart for cleaning the encoder and changing wipers but have never had to get involved with the actual ink lines before.
    19 March 2010 at 10:44
    you may have to lift a cover off to see the pump this should be bone dry if you have ink in there then pipe or pump failed.
    although its called a pump it actually sucks the ink so a air leak stops it working.
  • Jason Davies
    19 March 2010 at 11:30
    Have you manually cleaned the heads as well?
    Jason
  • John Dorling
    23 March 2010 at 15:31
    Thanks for suggestions on this. In the end I sorted it by doing a medium clean then printing a 1200 x 300mm block of 100% magenta on high quality. Wasted a lot of ink but at least it’s printing well now!
