Activity Feed › Forums › Sign Making Discussions › Off Topic Chat › Vivaro side moldings…How do you remove them?
Posted by Karl Williams on September 19, 2009 at 5:42 pmDoes anyone know how to remove the plastic moldings from the bottom side of a Vivaro van?
Karl Williams replied 14 years, 7 months ago 4 Members · 9 Replies -
hi karl
just took mine off
and snapped every single clip
vauxhall garage said pull straight off 👿
£7.00 for 10 and their is 72 clips dohthey will slide off just got in so cannot remember which way on each side so will post tomorrow morning
with some picsDerek
Thanks for the reply mate. That happened to me as well. If I can get the other side off without breaking any I think the 2 sides may have to share a few clips me thinks! 😳 😳 😉
When you have pulled the first corner away in dong so you may break this first clip, get a panel clip removing tool and work your way along the trim popping each clip as you go, a panel clip removing tool looks like a bent screwdriver with a u shape at the end which surrounds the round clip and makes removal simple with out breaking them all, also helps if the trims are warm as the clips are far less brittle. Rich
like the ones I use here also used for the same type clips on inside door trims
Richhttp://www.tptools.com/p/892,318_Door-P … Tools.html
morning karl i think best way is to knock them forward with a rubber mallet although i think they are designed to snap 👿
i have ordered some from an auction site will send you the linkgood luck
the clips richard has in mind are different but good idea to get the tools for those clips
derek
quote Derek Heron:morning karl i think best way is to knock them forward with a rubber mallet although i think they are designed to snap 👿
derek
Bugga!
Thanks guys. 😉 👿
hi Karl
still waiting for clips to arrive and spotted i can use the clips with only the one edge snaped off putting them opposite top and bottom
if you know what i mean hope it helpsDerek
Hello Derek,
I told the customer they’d broken and I’d get him some new ones and he was fine about it. He says his brother works for a vauxhall dealer so he’s taking it to him. He wouldn’t hear of me paying for them. It makes a change to deal with someone that’s geniune and normal. 😀 I’ll pop a pic on in a bit of the job.
Thanks mate. 😉 -
A right pair of Klutz’s 🙄 🙄 or should that be Kluti
quote Harry Cleary:A right pair of Klutz’s 🙄 🙄 or should that be Kluti
:baby: :baby: :baby: :baby: :baby:
