Home › Forums › Printing Discussions › General Printing Topics › vinyl printer
vinyl printer
Posted by Richard Urquhart on 6 October 2005 at 21:16is there a vinyl printer about that can print on to vinyl not to bothered about contour cutting but dont want to spend thousands
i.e are there any printers prices lower than £5000Andrew Bennett replied 20 years, 1 month ago 6 Members · 10 Replies -
The Mimaki JV3-75 model may come close enough to your figure to be worth considering. Sure, it’s more but it’s a real solvent printer and based on a proven platform. They’re about 13K US with a secondary cutter. I am sure they are available without the cutter bundled into to save a little bit of money.
I’m guessing this unit would be about 6200 pounds, without the cutter, based on my quick currency conversion.
Oh, Dave R here has the full-sized version of this unit so I am sure he can give you lots of details on the performance.
Good luck.
Rob
The JV3 models are excellent, we have a 160S but I sometimes use that 75SP in another company. The 75 is a cracking machine but i cant remember the price. The CG-FX plotter is pretty good, but you could invest in contour cutting at a later date.
One other thing, they advertise the printer as a 750mm wide machine but it will take 800mm (+5mm margin each side)
However don’t rule out the Cadet, same printer and heads just made by roland/uniform, you might find this is a cheaper system.
One thing I have found about the JV3 & CGFX cutter system, you can do two things at once (cut and print) and some bonuses for running a twin system, however on a budget then the Cadet seems a good deal.
I have read that some cadet owners are not getting perfect cutting (1-3mm out in some threads here), I have to say that the CG-FX cuts pretty damn accurate over 2-3 metres, I was shocked for a non-sproket cutter.
We did run into some registration issues longer then that but doing 100mm square small stuff is spot on accurate.I actually would like to see a close up of the media grips and the cutter, I want to see how many media grips it has?
http://www.uksignboards.com/index.php?nav_0=10 -
Rich, what are you looking at size wise?
If its for small stuff Gerbers can be picked up fairly cheap now,
but if you are looking to do large stuff you will struggle to find something decent on your budget.
peter -
quote :I have read that some cadet owners are not getting perfect cutting (1-3mm out in some threads here),
i am sure that is down to setting up my 540 is within half to quarter of a mm 95% of the time. it take time to set them up well but once done stay good over a long period.
rich i cant help thinking that there is going to be a glut of these machines with dead heads before long as the quoted price for head replacements ant good so careful with any thing pre owned.
well thanks all if any one has anythig for sale please let me know
dave rowland had a printer for sale i should have bid on that
any way looking for a second hand printer not a pc 60 or 600 as ihave one got around 3 grand but may stretch to morethanks all
hi richard, i had quite a response on that printer.. it is a good printer for an early one, bit of a learning curve but once mastered it is easy profit. Since I am not advertising (as it is sold now) .. it is very cheap running, particularly for banners and fascias, at times it can be vibrant but not the JV3 has much better detail for close work.
dave i think i saw it at 2800 and was talking to some one on getting there edge but ithink i offered them a bid to low and lost both could have kicked myself
the nicest thing about banging your head against the wall is the feeling you get when you stop !!!
Well we just sold our Edge to a member here…
I understand you do spraying… I guess you do vinyl… do u have a printer or CNC router? Are you one man band? -
Dave mostly cut vinyl and smaller stuff on the pc60
i packed in the spraying after 15 hard years 3 months ago finding things a nicer way of life
low over heads etc etc
and most of all I’m clean my hands now look like i could do an add for fairy washing up liquid -
quote Peter Normington:Rich, what are you looking at size wise?
peterWhat do you call fairly cheap please Peter?
And what can the Gerber do?
regards
Andy
