Home Forums Sign Making Discussions Vinyl Vinyl onto rear window of a van – advice pleeease!!
  • Vinyl onto rear window of a van – advice pleeease!!
    Posted by John Dorling on 21 August 2008 at 11:13
    Hi all,
    after some advice (again!)
    Got to put some graphics onto a rear window of a Fiat Doblo (tailgate back, so 1 piece of glass, presumably heated).
    Should I just use normal vinyl and put it on the outside (I think there’s a rear wiper), or do I reverse cut and apply to the inside (over the heating element)???
    Thanks is advance…
    John Dorling replied 17 years, 3 months ago 4 Members · 6 Replies
  • Cheryl Smith
    21 August 2008 at 11:31
    id ask the customer what they would prefer. I would always try to get away with doing it on the outside….with heating element wires etc etc, its always easier doing it on the outside and tidier but if customer really wants it for security purposes, then peeling off vinyl from the outside to look to see what is in the van is possible.
  • John Dorling
    21 August 2008 at 11:34
    Thanks Cheryl
    It’s only lettering so not sure if that makes a difference? Also it’s a Fiat Doblo car so it’s got windows and seats all round. Doesn’t leave a lot of room for graphics.
    Would you suggest a translucent vinyl or just anything with a clear adhesive?
    21 August 2008 at 11:40
    I’d do it on the outside with a good quality cast material. Less likely for the wiper to be an issue that way. Do it dry too. Less problems all round, and if you do get tiny bubbles, they’ll come out in a day or two because cast breathes better than cal – poly, or mono 😉
  • Cheryl Smith
    21 August 2008 at 11:45
    ditto Shane
    21 August 2008 at 11:54
    I do what Shane does, only he probably does it better.
    No wet app, use cast, not translucent, tell the client not to use their back window wiper for a few days and to park it in the sun the first day.
    I do use Oracal 651 on windows sometimes, but it chips easily with an ice scraper in winter.
    Not that the customer will admit to using one…
  • John Dorling
    21 August 2008 at 17:19
    Thanks for all the help – much appreciated. I’ll quote for it now…
