vinyl cutter – not cutting what I send?
I have a Liyu SC1261 with optical eye and have been using it without problem for months now.
The other day I tried doing some contour cutting and had problems – when trying to set up the offset when I used the PC keyboard to adjust the blade it had no effect. I gave up. Since then I have tried using the cutter for my normal one colour cutting and I cannot get it to work!!
I can set a test cut via the cutter itself and it works fine. I can set up my cutting job and request a test cut and that works fine too. BUT when I send the cut job to be cut I have been getting two scenarios:
1) There is a long pause then the blade will move to the far left of the cutter – and keep trying to move making an awful juddering sound so I quickly press reset.
2) More recently when I have tried re-setting the settings there is a long pause then the cutter will forward feed the vinyl and make a strange wiggly curve about 30cm wide then move further to the left and start cutting again – but I don’t know what it’s going to cut as I press reset as my vinyl is only 50cm wide and I have wasted too much already!
I have jobs waiting to be cut and need to get this resolved – does anyone have any ideas?
EDit: Should say I am using Windows Xp to Signcut Pro
